1999r1 rear brake caliper - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: 1999r1 rear brake caliper (/showthread.php?tid=65822) |
1999r1 rear brake caliper - 70s kid - 07-10-13 Hi all. Quick question fore yers, Has any one fitted a 99 r1 rear calliper to their fzs600. Are there any mods needed as it looks the same as a fazer 1000 rear one. All answers will be gratefully appreciated. 70s kid (Paul) Re: 1999r1 rear brake caliper - Chris - 07-10-13 Hi, Think the R1 has different spaces between the mounting bolts so it doesn't fit... using the search function might throw up the threads that mention it. To fit the R1 caliper would require a different caliper mounting plate which could in turn throw out the space for the rear wheel or not fit the rear axle spindle. If you think you can make it work then go for it, the fazer thou calipers are harder to find than an Essex virgin... The trx 850 rear caliper and mounting bracket fit without any mods too. Chris Re: 1999r1 rear brake caliper - darrsi - 07-10-13 (07-10-13, 06:45 AM)Chris link Wrote: Hi, http://www.ebay.co.uk/itm/Yamaha-FZS1000-FZS-1000-Fazer-03-Rear-Brake-Caliper-Read-Description-/181222248803?pt=UK_Motorcycle_Parts_13&hash=item2a31b01163 Re: 1999r1 rear brake caliper - Deefer666 - 07-10-13 As far as I know the TRX is the same as the R1and late model XJR and don't fit the 600. The FZS1000 caliper fits but you need the 600 hanger and you have to file about 1mm of material away from the arch between the to mounting holes on the hanger to get it to fit..... Also if you get the torque arm which is ali you can use that and junk the crappy steel torque arm that is standard fitment for the 600 Re: 1999r1 rear brake caliper - TonyW - 07-10-13 TRX850 hanger with a YZF750 rear caliper on mine. It bolts straight on although you need a longer brake pipe if the standard one is still fitted. Mine had a braided hose of unknown origin fitted when I bought it. Re: 1999r1 rear brake caliper - Deefer666 - 07-10-13 Ahhh so to get the r1 style caliper to fit you need a trx hanger, Thats interesting to know Re: 1999r1 rear brake caliper - Chris - 09-10-13 (07-10-13, 06:48 AM)darrsi link Wrote: [quote author=Chris link=topic=10208.msg106181#msg106181 date=1381124723] http://www.ebay.co.uk/itm/Yamaha-FZS1000-FZS-1000-Fazer-03-Rear-Brake-Caliper-Read-Description-/181222248803?pt=UK_Motorcycle_Parts_13&hash=item2a31b01163 [/quote] Thanks for that Darrsi, what I should have said is that they are hard to find and if you do they are usually very expensive... |
