headlights misting up - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: headlights misting up (/showthread.php?tid=65812) |
headlights misting up - fatbloke62 - 05-10-13 Hi all. first timer here ,been very happy with my gen 1 since I got it earlier on in the year but noticed of late that the headlamps mist up inside (not got it wet ) anyone had anything similar ?(feel free to pull the newbies chain) Re: headlights misting up - mickvp - 05-10-13 Make sure your rubber rings at the back are sealed properly. To solve the problem get hold of some silica beads (you usually get packs in new trainers, or eBay), and lace them inside the seal somewhere to absorb the excess moisture, which will help dry them out initially. Re: headlights misting up - seangee - 05-10-13 Plain old rice (uncooked) does a pretty good job of removing the moisture - but you do have to fix the seal. I stuck a bag of "boil in the bag" behindĀ the cars headlight unit and never had a problem since. Re: headlights misting up - g5guzzi - 05-10-13 The heat from the bulb in use will dry it out. malc Re: headlights misting up - mickvp - 05-10-13 (05-10-13, 11:13 PM)g5guzzi link Wrote: The heat from the bulb in use will dry it out. Not so. If you fix the seal, the heat from the bulb will allow the water to evaporate, yes, but where is it to go if you sealed the leak? The point of silica gel/rice is to allow the evaporated water somewhere to absorb into, otherwise it would just. Condense again when you turned the lights back off. Re: headlights misting up - dazza - 06-10-13 Take off the rubber seal, remove the bulb and give it a good old dowse with talcom powder. |
