Worn gear change lever bush HELP - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Worn gear change lever bush HELP (/showthread.php?tid=65711) |
Worn gear change lever bush HELP - Gav - 29-09-13 Hi folks I am looking for advice on how to replace or where I can get a new gear change lever with new bush. My yr 2000 fzs600 has seen a helluva lot of miles and gear changes and the lever is uber waggly. Would love it to be as new again. Is there an off the shelf item I can get non genuine / affordable item or is it down to the local cnc/ machine shop to sort me out? Cheers Gav Ps I've not stripped it yet so maybe the shaft needs replacing too? Re: Worn gear change lever bush HELP - darrsi - 29-09-13 http://www.ebay.co.uk/sch/i.html?_trksid=p2050601.m570.l1313.TR12.TRC2.A0.Xfzs+600+gear+lever&_nkw=fzs+600+gear+lever&_sacat=0&_from=R40 http://www.yamahamotorcyclespares.co.uk/genuineparts/9657/19/yamaha%20fzs600sp%20fazer/shift%20shaft?uID=0 Re: Worn gear change lever bush HELP - Gav - 29-09-13 Cheers then, will ava look but none instock on the second link you gave boohoo Re: Worn gear change lever bush HELP - Punkstig - 29-09-13 Shift shaft, Giggity |
