AIS removal - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: AIS removal (/showthread.php?tid=65659) |
AIS removal - esetest - 25-09-13 I am planning to paint the rocker cover during the winter months , which will involve removing the radiator and the AIS . It would seem a good idea to replace the AIS with the Ivan's AIS removal kit , which appears to be a cheap mod and Pats motorcycle page has a step by step guide . But the instructions do warn that removing the AIS can cause the bike to fail the emissions part of the MOT , has anybody experienced this . Thanks in advance for any advice . Re: AIS removal - Tmation - 25-09-13 there is no MOT emissions test for bikes at the moment Re: AIS removal - fireblake - 25-09-13 I think that is for American bikes. mine went straight through its MOT Mickey Re: AIS removal - esetest - 26-09-13 Doh , I should have known that , I shall order a kit and get that done during winter break . Re: AIS removal - Falcon 269 - 26-09-13 Hold on ordering the kit. Get 4 x M8 stainless socket head bolts, 12mm long is enough, and a good quality M8 HSS tapered tap and you can do exactly the same for a fraction of the price. I can't stress enough the importance of getting a good tap, though ... none of yer cheap rubbish or it will end in tears. And tapered, OK? Re: AIS removal - esetest - 26-09-13 Hi Falcon , thanks for the tip , do you know the dia of the rubber caps , I was thinking of the rubber sleeves they put on the end of cable flexes as an alternative . Re: AIS removal - Falcon 269 - 27-09-13 The cap on the vacuum stub in the carb rubber is the same as the other three. Or, you can just trim the AIS hose there and plug it with a bolt. I used a cap from a milk carton or something like that to cover the airbox stub. Dab of silicon, job's a good 'un.
Re: AIS removal - esetest - 27-09-13 Cheers for the advice . |
