Exup Squeal - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Exup Squeal (/showthread.php?tid=65638) |
Exup Squeal - old son - 24-09-13 Fitted the replacement servo, all good. I now hear a short squeal when the ignition is first turned on. Could this denote anything nasty or is it just the servo resetting itself? Re: Exup Squeal - brooker81 - 24-09-13 Maybe cables are slightly too tight. thats what mine used to do backed off a little queek stopped
Re: Exup Squeal - fazer390 - 24-09-13 A lube of the Exup valve should solve your squeal mate...
Re: Exup Squeal - old son - 24-09-13 (24-09-13, 11:32 AM)fazer390 link Wrote: A lube of the Exup valve should solve your squeal mate... Its all copper slipped up. The valve runs very smoothly with no resistance. Re: Exup Squeal - b1k3rdude - 24-09-13 Good to hear the servo is doing its job, it been sitting in my spares box for ages
Re: Exup Squeal - pitternator - 25-09-13 mine does this too, and its lubed and adjusted. But lube does burn off after time and I think its the initial release of the exup in the plain bearing on start up. Its done this for last few years ...so I might deduce its nowt to worry about , and mine is due another strip and lube. Re: Exup Squeal - old son - 25-09-13 Could it just be the initial movement of the servo? It sounds like it is coming from there rather than the Exup itself. My original motor did the same thing for a couple of months before it stopped working. I checked the inside of the old servo and it is full of plastic cogs and a little grease. Nothing to make the noise that I could see. |
