cold starting - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: cold starting (/showthread.php?tid=65632) |
cold starting - dickturpin - 23-09-13 The last two times I have started the bike from cold it's taken many attempts to catch. (I don't use choke) I'm not sure if this is a problem or not yet and will see how the next few go. bike has a new battery with loads of umph so not that. What would you set about checking? Its not ivanised (that I know of). When it does fire its very lumpy until I can gradually increase revs. When its warm it runs fine so I don't think its a carb balance problem. It also starts straight away when warm. This isn't a major issue yet but looking for suggestions to investigate. I realise all stock fazers can be a little tricky to start but the last couple have seemed worse. Re: cold starting - slimwilly - 23-09-13 Weak spark,why not use choke? Maybe petrol wet plugs, or bad plugs Re: cold starting - dickturpin - 23-09-13 Never really needed choke....maybe half choke in winter that's all. Re: cold starting - Capt - 23-09-13 Use the choke that's what it's for, Ivanising reduces the need of the choke when cold but it will still need it. Re: cold starting - devilsyam - 23-09-13 pre ivan always use choke even then may be two attempts but capt is spot on Re: cold starting - dickturpin - 23-09-13 ok, i'll try next time...maybe I've just got into bad/lazy habits! |
