VHT Flameproof Paint - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: VHT Flameproof Paint (/showthread.php?tid=65473) |
VHT Flameproof Paint - hightower - 12-09-13 My engine block looks so tatty with the paint flaking. I was given a tin of something like this: http://www.ebay.co.uk/itm/VHT-BLACK-FLAMEPROOF-EXHAUST-COATING-PAINT-SP102-/350869502666 from a lad at work - the picture on it is of the exhaust pipes, but would this sort of stuff go on to the engine block just as well? If so would it just be a case of: 1) Clean parts to be sprayed 2) Mask parts not to be sprayed 3) Spray? Re: VHT Flameproof Paint - darrsi - 12-09-13 http://foc-u.co.uk/index.php/topic,8354.msg82143.html#msg82143 Re: VHT Flameproof Paint - hightower - 12-09-13 Thanks, so paint should be alright? Re: VHT Flameproof Paint - darrsi - 12-09-13 I used Plastikote spray, which isn't classified as high temp. spray and it's holding up fine. Just make sure you thoroughly degrease anything you spray otherwise it'll cause you problems. Re: VHT Flameproof Paint - hightower - 12-09-13 Yeah, there a particular brand or just good old soap and water? Re: VHT Flameproof Paint - Dead Eye - 12-09-13 Proper degreaser would be better first - something like Ultra Gunk which you can get from Halfrauds or fleabay Re: VHT Flameproof Paint - darrsi - 12-09-13 I used Gunk from a spray can but brushed it into all the nooks and crannies, then i jetwashed it off, which blew half the paint away but that wasn't really a bad thing, then smoothed down what was left with wet 'n' dry. Re: VHT Flameproof Paint - red98 - 12-09-13 ive used that VHT paint on my downpipes for years,very good paint,bit overkill on the engine.....as darrsi suggests , use plasticote,lots and lots of de-greasing is the key......pun intended :lol Re: VHT Flameproof Paint - fazersharp - 12-09-13 Down pipes for me is Granvile cylinder black satin and once painted on you need to start up and heat up, you will see smoke and it smells a bit but it kind of bakes on. Im thinking of touching up my flat tops of fins with it. Comes in a tin and I cant see any brush strokes on the exhausts. It sticks to anything as I got some on the shiney bits and its a bugger to get off. Dont think I would do big flat areas with it tho Re: VHT Flameproof Paint - Punkstig - 12-09-13 I've used Hammerite on the engine with no problems! Re: VHT Flameproof Paint - jason1 - 14-09-13 I used barbecue paint on my engine , gave it a real good rub down , degrease , masked up and sprayed . Works a treat , also sprayed down pipes at same time . Used all weathers and still looking good . Re: VHT Flameproof Paint - nick crisp - 14-09-13 (12-09-13, 07:34 PM)Punkstig link Wrote: I've used Hammerite on the engine with no problems! Don't listen to him, this is the only guy I know who REALLY needs flameproof paint! |
