Headlight Mod - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Headlight Mod (/showthread.php?tid=65408) |
Headlight Mod - bbb - 08-09-13 Did the headlight mod yesterday, very good write-up, bought the connectors from Autostar on ebay (cheap and next day delivery) included a waterproof connector that now sits behind the clocks in case of any MoT issues. Just need to adjust the beams (inner for vertical??) now. ![]() Also ordered a 2.8mm female connector from autostar to replace the blue heatshrink part that should in theory enable me to use the blue connector under the tank. ![]() Considering removing the metal cover over the dipped beam, has anyone had any issues at MoT time with the cover removed? Cheers Re: Headlight Mod - darrsi - 08-09-13 Adjust at night or in a dark garage, it's much easier. If you mean that metal shroud thingy, they just end up vibrating and either fall off or get removed. Re: Headlight Mod - Dead Eye - 09-09-13 The metal shroud I removed on mine and it went through its MOT fine
