Draper Compression Tester - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Draper Compression Tester (/showthread.php?tid=65312) |
Draper Compression Tester - humbucker88 - 02-09-13 Has anyone used the draper compression tester before? It doesn't actually seem to fit under the frame to use it... Re: Draper Compression Tester - red98 - 02-09-13 (02-09-13, 03:44 PM)humbucker88 link Wrote:Has anyone used the draper compression tester before? It doesn't actually seem to fit under the frame to use it... is it the push in type.....ive got the screw in thpe with flexible hose....works a treat and is more reliable
Re: Draper Compression Tester - humbucker88 - 02-09-13 It's the useless type. Screw in. http://www.ebay.co.uk/itm/130969665378 See the long gold bit on the hose? Well it's a 14mm type, needs the biggest adaptor on it to fit, so now there's a giant gold pole on the end of the tube, which won't fit under the frame to allow it to be screwed in, ridiculous. |
