 Oil Plug beside oil level window? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Oil Plug beside oil level window? (/showthread.php?tid=65293) Pages:
Oil Plug beside oil level window? - bmseven - 01-09-13 Went out for a ride today only to be covered in oil from the little allen cap beside the oil level window. Tried tightening it but it just fell apart in my hands anyone know what its purpose is/what its called or where to get one from Its an allen bolt with a rubber O ring? Thanks in advance Tone Re: Oil Plug beside oil level window? - darrsi - 01-09-13 http://www.YAMAHAscooterspares.co.uk/genuineparts/9656/14/yamaha%20fzs600%20fazer/crankcase%20cover%201?uID=0 Re: Oil Plug beside oil level window? - darrsi - 01-09-13 Not sure if that exact link is what you need but that website will help you anyway. Re: Oil Plug beside oil level window? - bmseven - 01-09-13 Cheers Darrsi bookmarked that one   Still not sure what its for though Item 8 Plug! http://www.yamahascooterspares.co.uk/product/yamaha/36Y151890000/plug?uid=0 ![]() Re: Oil Plug beside oil level window? - andybesy - 01-09-13 How much oil came out? Re: Oil Plug beside oil level window? - darrsi - 01-09-13 Any reason why your link opened up on the FZR Genesis page? Re: Oil Plug beside oil level window? - bmseven - 01-09-13 Andybesi Quite a lot of oil spray all down the side and under the bike over the pads ![]() darrsi Opens up on FZS600 for me ! Re: Oil Plug beside oil level window? - darrsi - 01-09-13 How strange? Re: Oil Plug beside oil level window? - unfazed - 01-09-13 It is called an oil gallery plug and plugs the end of the main oil gallery which supplies oil under pressure to the crank bearings.There is also one on the other side directly oppisite. It can be used to check the oil pressure by removing the plug and attaching an oil pressure guage to it. When you replace the plug, replace the O ring also and tighten it to 8 Nm and do not overtighten it as it is easily broken. Re: Oil Plug beside oil level window? - Lez72 - 02-09-13 Can this plug be removed without draining the engine oil ? I need to change mine too
Re: Oil Plug beside oil level window? - bmseven - 02-09-13 Unfazed - Thanks for the info you learn something every day ![]() Lez72 - I have drained the oil and changed the filter but with the plug out oil was still leaking out. The plugs location is slightly above the window but obviously as unfazed says an oil gallery without draining all oil a minimal loss seems unavoidable less so if your quick Parts ordered from dealer Yamaha plug Part No/ 36Y151890000 £12.04 Yamaha O ring Part No/ 932101662900 £1.81 Many thanks everyone Re: Oil Plug beside oil level window? - Dead Eye - 02-09-13 You MIGHT be able to get away with doing the right hand side one next to the window if you put the bike on the side stand - you can remove the clutch cover safely doing this so... Re: Oil Plug beside oil level window? - unfazed - 02-09-13 As Dead Eye says you should be able to change the right one with minimal oil loss with the bike on the side stand. The left side could be changed the same way if you get some way or some one to support the bike tipped over to the right. Re: Oil Plug beside oil level window? - DanielT - 23-12-13 (01-09-13, 10:42 PM)unfazed link Wrote:It is called an oil gallery plug and plugs the end of the main oil gallery which supplies oil under pressure to the crank bearings.There is also one on the other side directly oppisite. It can be used to check the oil pressure by removing the plug and attaching an oil pressure guage to it. When you replace the plug, replace the O ring also and tighten it to 8 Nm and do not overtighten it as it is easily broken. This is extremely true. Now supposing a complete donut overtightened it, and the head snapped off, leaving the bolt inside. How would aforementioned donut remove it? All ideas gratefully received! Edit: Trend Pro Grabit. £18 from screwfix solved the problem. Relief! Re: Oil Plug beside oil level window? - bmseven - 23-12-13 The head fell apart on mine but the recess goes into the engine so was able to unscrew with an allen key Re: Oil Plug beside oil level window? - DanielT - 23-12-13 (23-12-13, 09:34 PM)bmseven link Wrote:The head fell apart on mine but the recess goes into the engine so was able to unscrew with an allen key half of the allen key recess was gone too, so there wasn't quite enough grip. tried to epoxy the bit to it first, but no joy. Thanks for the part numbers, I've ordered them. :thumbup Re: Oil Plug beside oil level window? - fazersharp - 23-12-13 So should we all change ours before we all suffer the same. Cant see why the plug is so expensive tho. Having just changed the coolent - when you remove the drain plug nothing comes out untill you take off the filler cap- wouldnt this be just the same, or even less so as the oil is thicker and is not so far above the draining hole and so dosent have a head of pressure above Re: Oil Plug beside oil level window? - darrsi - 23-12-13 (23-12-13, 10:38 PM)fazersharp link Wrote:So should we all change ours before we all suffer the same. Don't touch it.........in fact, pretend you never saw this post. Re: Oil Plug beside oil level window? - richfzs - 23-12-13 fazersharp, this tells you all you need to know... ![]() Re: Oil Plug beside oil level window? - His Dudeness - 23-12-13 It's sure to be siezed. you'll have to drift it out with a size 4 hammer  |
