New downpipe needed for 1998 model, what can i use? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: New downpipe needed for 1998 model, what can i use? (/showthread.php?tid=65284) |
New downpipe needed for 1998 model, what can i use? - Mike @ Bristol - 31-08-13 I've had a scout around on fleabay, but got confused. can i use downpipes for later models? Or do i need to buy 1998 specific pipes? Cheers Re: New downpipe needed for 1998 model, what can i use? - Craiginuk - 31-08-13 Give these guys a call, i had these on my last fazer and the fit was perfect. First set snagged centre stand but they replaced same day. Good guys to deal with. http://www.ebay.co.uk/itm/FZS600-FZS-FAZER-600-EXHAUST-PIPES-DOWNPIPES-FRONTPIPES-HEADERS-/141050618129?pt=UK_Motorcycle_Parts_13&hash=item20d745a111 Re: New downpipe needed for 1998 model, what can i use? - Mike @ Bristol - 31-08-13 Thanks for the quick reply Craig, and those pipes look really nice, but i'm hoping to find something a bit cheaper, some decent second hand pipes would be good. If not, i'll keep them in mind, they'd look great. Re: New downpipe needed for 1998 model, what can i use? - Craiginuk - 31-08-13 Pretty sure they are all the same but sure someone else will be able to confirm. Re: New downpipe needed for 1998 model, what can i use? - Mike @ Bristol - 31-08-13 Seen some second hand pipes in the for sale section here but i think it'll be worth paying the bit extra to have some shiny new stainless steel pipes. The more I think about it, the more i want them. Cheers for the link, i'll probably put the order in. Re: New downpipe needed for 1998 model, what can i use? - darrsi - 31-08-13 Get some used ones and spend £15 on Optiglanze and you can make them look like new!
Re: New downpipe needed for 1998 model, what can i use? - Dead Eye - 31-08-13 Yes, downpipes from any FZS 600 will fit (NOT the FZ6 though) Sandy bike spares are well known and are usually about the cheapest for new stainless steel. Most will recommend Motad though as they have the balance pipes between cylinders 1+2 and 3+4 which helps with the midrange Re: New downpipe needed for 1998 model, what can i use? - ChristoT - 31-08-13 (31-08-13, 11:37 PM)Dead Eye link Wrote:Yes, downpipes from any FZS 600 will fit (NOT the FZ6 though) But as others with the Sandy spares will tell you - the difference is barely noticeable anyway!! Re: New downpipe needed for 1998 model, what can i use? - Punkstig - 01-09-13 Phone motad directly, tell them you noticed a set of theirs for about £150 on eBay and do they have another set, works most times with them! Re: New downpipe needed for 1998 model, what can i use? - fazerboy01 - 01-09-13 Ive got Delkavic SS pipes, perfect fit, no noticable diff in power, clean up a treat when used all winter in all weathers. Re: New downpipe needed for 1998 model, what can i use? - Mike @ Bristol - 01-09-13 Thanks for all the above advice. Much appreciated. The Delkavic pipes will prob be the winner. Re: New downpipe needed for 1998 model, what can i use? - bbb - 03-09-13 Post up how you get on with the delkevic pipes, discovered mine have holed in the 2-1 collector :'( so also looking for a set before the MoT. Re: New downpipe needed for 1998 model, what can i use? - Mike @ Bristol - 03-09-13 Ok, no probs, I haven't got round to ordering anything yet but which pipes have you got which have holes in? Cheers Re: New downpipe needed for 1998 model, what can i use? - bbb - 05-09-13 My pipes have a rust hole in the collector, don't know if you have the same issue but I called NRP exhausts in Newark, Notts and he gave me a ballpark £20 to weld up and an additional £30 to sandblast and re-paint. I'm sending him some photos for a more accurate quote. Much cheaper than replacing them. Re: New downpipe needed for 1998 model, what can i use? - gassitt - 06-09-13 No not all pipes are the same Yes all will fit but the angle of the tail pipe will be slightly different between early 98 99 models and the 2000 on bikes as the rear footrest hangers are lower on the later bikes So when it comes to fitting your end can and getting the bolt for the strap to line up, if youre using later model pipes on an early bike it may not quite line up without a bit of pulling Its normally possible but can make you think you have the wrong pipes Re: New downpipe needed for 1998 model, what can i use? - Mike @ Bristol - 10-09-13 Delkevic pipes ordered. woohoo. I'll take some before and after pics once fitted. Looking forward to the upgrade. Re: New downpipe needed for 1998 model, what can i use? - Frosties - 11-09-13 (31-08-13, 10:38 PM)Mike @ Bristol link Wrote: I've had a scout around on fleabay, but got confused. can i use downpipes for later models? Or do i need to buy 1998 specific pipes? Cheers You should have said earlier fella - would have got you some when I had the end can off of ChristoT's bike :rolleyes . Re: New downpipe needed for 1998 model, what can i use? - Arfa - 11-09-13 Do report back, need some new pipes and ideally new can too. Currently in split mind between Venom/Motard and the Delkevic pipes Re: New downpipe needed for 1998 model, what can i use? - Mike @ Bristol - 11-09-13 (11-09-13, 07:45 AM)Frosties link Wrote: [quote author=Mike @ Bristol link=topic=9664.msg98136#msg98136 date=1377985116] You should have said earlier fella - would have got you some when I had the end can off of ChristoT's bike :rolleyes . [/quote] No probs, I'm happy to invest in some shiny new ones. Thanks though. |
