help - Printable Version
+--- Thread: help (/showthread.php?tid=65075)
help - kenny59 - 19-08-13
Picked up my 07 fazer on saturday first proper ride on it going to work and realised the indicators aren't working can this just be a fuse ?
Re: help - Grahamm - 19-08-13
Presuming all the other lights are working (headight, side-lights, rear and brake lights), try the Hazard Warning light switch.
If this gets no reaction, remove the right hand rear fairing panel (by the seat) to find the fuses. There should be a separate one marked "Park", check this with a multi-meter and replace it with another 10 amp one if needed.
If it goes again immediately, or you still get no indicators that suggests bigger problems and someone else will have to help you with that!
Re: help - AdieR - 19-08-13
Did you buy the bike privately or from a dealer?
Try your fuses first and let us know how you get on.
Re: help - kenny59 - 19-08-13
It wasn't the fuse but with messing they started working it looks like a bad connection at the switch its still under warranty so will ask them to take a look thanks for all the advice
Thanks for the update, hope you get it sorted :thumbup
