seized brake retaining pin - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: seized brake retaining pin (/showthread.php?tid=64979) |
seized brake retaining pin - shaun2874 - 12-08-13 hi guys im looking for some advice, the retaining pin that holds the pads in the front caliper is seized solid :'( ,,,,,,i need to change the pads but it aint shifting, im starting to think i will need a blowtorch to move it. bothe front Ines are seized,,,,,any tips and help plz lol Shaun Re: seized brake retaining pin - Kentish - 12-08-13 Get in it a vice with some soft jaws then spray it with plus gas then try twisting it out with molegrips Re: seized brake retaining pin - darrsi - 12-08-13 When you hopefully remove them unscathed, give them a good clean up and use copper grease before refitting, and if you also torque them correctly it "shouldn't" happen again!
Re: seized brake retaining pin - shaun2874 - 12-08-13 Cheers guys,,,,, estesi its the pin that slides through the caliper that holds the pads in place and is secured with 2 pins lol Re: seized brake retaining pin - darrsi - 12-08-13 (12-08-13, 12:06 PM)shaun2874 link Wrote: Cheers guys,,,,, estesi its the pin that slides through the caliper that holds the pads in place and is secured with 2 pins lol "...estesi..." ??? Re: seized brake retaining pin - Dead Eye - 12-08-13 In the past I've used an allen key, or a screwdriver and on one occasion a punch (the proper tool ) to drive the pin out Any sort of penetrating fluid will help as well
Re: seized brake retaining pin - shaun2874 - 12-08-13 Sorry darrsi, predictive text on my phone,,,,,lol Re: seized brake retaining pin - Jacko - 12-08-13 Check for bits of R clip stuck in there then drift it out as per dead eyes method. Re: seized brake retaining pin - His Dudeness - 12-08-13 Drift: Verb. Meaning to beat the crap out of someting with a sledge :lol Re: seized brake retaining pin - Dead Eye - 13-08-13 (12-08-13, 10:35 PM)His Dudeness link Wrote: Drift: Verb. Meaning to beat the crap out of someting with a sledge :lol Haha, sounds about right... I usually start with a rubber mallet, decide its boring and then beat it in to submission with the largest hammer I have
Re: seized brake retaining pin - shaun2874 - 13-08-13 Well im off work tomorow, so ive bought some penatrating oil(ooer missus) and borrowed a blow torch as a last measure,,,,lol so countdown to either victory or mayhem Re: seized brake retaining pin - Deefer666 - 14-08-13 remove the caliper from the bike, pack all around the pin with cotton wool and then soak the cotton wool in diesel. Leave for for a day and the pin will drop out. |
