Forking Forks ! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Forking Forks ! (/showthread.php?tid=64909) |
Forking Forks ! - Looney tune - 07-08-13 On my last couple of outing (while back now ) I heard a noise coming from the front end, like a gentle knock, every now and then on bumpy surfaces. Last night I went for a spin and the noise is there every time I run on / over a rough surface. When I hold the front brake on and push on the bars to compress the suspension it does it every time on the way down. When a friend does it and I hold the fork legs I can feel it as well as hear it. I have checked brakes, mud guard and anything else that might be loose on or to do with the forks / head stock. Bike is a 2008 FZ1n with 10600 miles. Has anybody had this before or can point me in the right direction for a fix ? Many thanks, Russ Re: Forking Forks ! - jackojet - 07-08-13 Hi Russ Is it the brake pads rocking in the calipers against the pins? My gsxr was a twat for it. Try giving your brakes a spray with brake cleaner
Re: Forking Forks ! - Looney tune - 08-08-13 Hi Pete, thanks for the reply. When I checked the pads they had a little movement yes, but when I jammed them 'solid' with a screw driver and bounced the front end the noise was still there.. The mystery continues, what about fork oil ? Worth a change ? Re: Forking Forks ! - stevierst - 08-08-13 My fz1s does that too! Not particularily worried, but it would be nice to find out what it is. Re: Forking Forks ! - AyJay - 08-08-13 FZ1s have compression in one leg and damping in the other, I believe. Is it coming from one side? Re: Forking Forks ! - Exupnut - 08-08-13 We thought u were gonna come back Re: Forking Forks ! - unfazed - 08-08-13 4 items could cause what you describe Brake Pad Pins - You seem to have ruled this out Worn Fork bushes - mileage probably to low for this Wheel bearings. - Remove calipers and lift the front . Grab wheel top and bottom Try and rock it left and right Head Race Bearings - If they are not notchy then it might be worth while retorquing them. Cover the tank to prevent damage. Remove the handlebars (makes the job easier) Loosen the top fork pinch bolts Remove the steering stem nut and washer (This is tight 113Nm) Lift off the top yolk Remove the lock washer Remove the first ring nut Remove the rubber washer Loosen the second ring nut At this point decide if you want to go further and regrease both top and bottom bearings If you decide not to, then Tighten 2nd ring nut to 52Nm - Requires special tool to do it properly. I made one out of an old rear shock adjusting tool. Loosen it again (not to much) and retighten to 18Nm (do not tighten more than 18Nm) Refit the rubber washer Refit the top nut and tighten to a good finger tight and refit the lock washer. Refit the rest in revere order of removal. The steering stem nut is 113Nm Upper Fork leg pinch bolts are 26Nm Hopefully that will solve it. Re: Forking Forks ! - Looney tune - 14-08-13 (08-08-13, 09:01 PM)AyJay link Wrote: FZ1s have compression in one leg and damping in the other, I believe. Is it coming from one side? Sorry, been busy. It's on both sides thanks. (08-08-13, 11:35 PM)unfazed link Wrote: 4 items could cause what you describe As above, sorry for late reply. Wheel bearings were fine when doing initial checks so I will check the head race bearings and many thanks for the info on how to do this, great stuff. I will report back when I have carried out the work required, could be a while as it's silly season at work tho :'( Thanks again. |
