12mm front brake caliper bolts - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: 12mm front brake caliper bolts (/showthread.php?tid=64827) |
12mm front brake caliper bolts - Sealion127 - 02-08-13 hi , anyone know where i can get 4 from , seen some on ebay but there £20!!, mine were seized on and rounded off , took a hammered on 11mm socket to shift them . cheers in advance chris Re: 12mm front brake caliper bolts - darrsi - 02-08-13 Always helpful if you list what year of bike you have in your profile, but i'd imagine they're all the same. (no.25 & no.14, but they are the same bolt and part number) http://www.yamahamotorcyclespares.co.uk/spares/epc2.asp?modelID=9656&PageiD=30&m=YAMAHA+FZS600+Fazer+FRONT+BRAKE+CALIPER&uID=0 Re: 12mm front brake caliper bolts - Dead Eye - 03-08-13 You can find the size and thread pitch from the workshop manual and then just buy them on eBay - I did this recently for the two rear caliper mounting bolts ![]() The download is here http://foc-u.co.uk/index.php?action=downloads;sa=view;down=8 The Front Brake caliper bolts should be M8 x 1.25 Unfortunately it doesn't show length BUT that is by far the easiest thing to measure Just remember that length is from the base of the bolt head to the end of the thread (so basically doesn't include the bolt head)
Re: 12mm front brake caliper bolts - mars696 - 03-08-13 Because i recently change them,the bolts are M10 x 1.25. The manual says M8 but its wrong. I used 10.9 metric(which is 8 grade american).DOnt use soft bolts there! Hope it helps!
Re: 12mm front brake caliper bolts - nick crisp - 03-08-13 Don't these bolts have to be of a certain tensile strength? Re: 12mm front brake caliper bolts - Dead Eye - 03-08-13 (03-08-13, 10:41 AM)mars696 link Wrote: Because i recently change them,the bolts are M10 x 1.25. The manual says M8 but its wrong. Really? I thought the rear were M10 and the fronts M8 especially since they take a different socket - at least that's the case on my bike :| I'll check in a minute as I'm working in the garage today on the bike anyways
Re: 12mm front brake caliper bolts - nick crisp - 03-08-13 (03-08-13, 10:44 AM)nick crisp link Wrote: Don't these bolts have to be of a certain tensile strength? Don't want to harp on about this, but I think it's actually pretty important. I believe the torque settings on these bolts are quite high, that's one reason for the tensile rating requirement. Also, if I remember right, they need to be Loctited in place when you refit them. Re: 12mm front brake caliper bolts - mars696 - 03-08-13 Nick, If i remember well the oem bolts are 8 grade,wich is the equivalent of 10.9 in metric system. Of cource we can use titanium bolts but the price is prohibitive. :'( Re: 12mm front brake caliper bolts - nick crisp - 03-08-13 I just wanted to be sure that people don't just use any old bolts as the discussion here seemed to be more about sizes with no mention of other requirements. I know you'd already mentioned this mars696, but wanted to make sure people picked up on it. I've got nothing better to do, sorry! Re: 12mm front brake caliper bolts - mars696 - 03-08-13 You are right,safety first!!!
Re: 12mm front brake caliper bolts - Dead Eye - 03-08-13 Well, my results were unhelpful... I forgot that the previous owner was a bit mad and so I have three different sized hex bolts holding my calipers on - 1x 14mm, 1x 13mm and 2x 12mm If nothing else, my bike has character... Re: 12mm front brake caliper bolts - darrsi - 03-08-13 No need to Loctite them, if they're torqued correctly they're going nowhere. Re: 12mm front brake caliper bolts - nick crisp - 03-08-13 (03-08-13, 12:51 PM)nick crisp link Wrote: [quote author=nick crisp link=topic=9207.msg92172#msg92172 date=1375523061] Don't want to harp on about this, but I think it's actually pretty important. I believe the torque settings on these bolts are quite high, that's one reason for the tensile rating requirement. Also, if I remember right, they need to be Loctited in place when you refit them. [/quote] (03-08-13, 01:01 PM)mars696 link Wrote: Nick, (03-08-13, 01:33 PM)nick crisp link Wrote: I just wanted to be sure that people don't just use any old bolts as the discussion here seemed to be more about sizes with no mention of other requirements. I know you'd already mentioned this mars696, but wanted to make sure people picked up on it. I've got nothing better to do, sorry! (03-08-13, 01:36 PM)mars696 link Wrote: You are right,safety first!!! (03-08-13, 01:42 PM)Dead Eye link Wrote: Well, my results were unhelpful... I forgot that the previous owner was a bit mad and so I have three different sized hex bolts holding my calipers on - 1x 14mm, 1x 13mm and 2x 12mm :rollin Aaaaaagh! :rolleyes :'( :lol Re: 12mm front brake caliper bolts - Sealion127 - 03-08-13 thanks for the help and advice , i will order some titanium ones i think . |
