2001-2002 carb inlet rubbers wanted. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: For Sale & Wanted (https://foc-u.co.uk/mybb/forumdisplay.php?fid=80) +--- Thread: 2001-2002 carb inlet rubbers wanted. (/showthread.php?tid=64782) |
2001-2002 carb inlet rubbers wanted. - neil2do - 31-07-13 hi all just purchased a 2002 600 fazer and noticed one of the carb inlet rubbers are cracked so i am looking for a full set anyone got any. cheers neil2do............ located in the uk. Re: 2001-2002 carb inlet rubbers wanted. - lds1973 - 31-07-13 Is it running like shit? All four of mine are cracked and it runs great. Its common for them to look cracked but be totally air tight. Unless they are affecting the running then save your money. Re: 2001-2002 carb inlet rubbers wanted. - Fazerider - 31-07-13 :agree Check them, but even if they look terrible the chances are they're nowhere near to cracking all the way through. The outer ones usually suffer more so if it's just the appearance that bothers you, swap 'em with the inner ones. Alternatively, you can also use black silicone sealant to fill the cracks. Re: 2001-2002 carb inlet rubbers wanted. - neil2do - 31-07-13 hi thanks for your quick response and advice they are cracked and have been sealed thought they were nackerd by the sound of it there ok bike runs well bit of cam noise and i bit lumpy on tick over guess i will leave them for now just going through everything and discoverd the crack on the rubber. thats one of a few things sorted cheers chaps................ Re: 2001-2002 carb inlet rubbers wanted. - unfazed - 31-07-13 Why would you buy something like this secondhand and have the same problem again in a few 1000miles. :rolleyes You can buy brand new ones from M&P are less than £80
