Chain and sprocket question - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Chain and sprocket question (/showthread.php?tid=64715) |
Chain and sprocket question - bellycgb - 26-07-13 OK so ive just bought this DID chain and sprocket kit from ebay :- http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=321040757202, it arrived today and a couple of things puzzled me, the front and rear sprockets are different brands - powerite front and jt back, is this normal? the auction says its a VXBG chain with is the heavy duty one but on the chain itself it says VX which is the standard one? any other way to tell what chain you have? have a look
Re: Chain and sprocket question - elbrownos - 26-07-13 I've never bought a chain so I'm no expert but a quick google leads me to believe GB means gold & black, not heavy duty. Heavy duty is just what they call their chain that isn't gold & black. That ad is definitely for gold & black chain (which costs more) so you've been had. Wouldn't worry about the sprockets though. Re: Chain and sprocket question - Punkstig - 26-07-13 The DID VX is a heavier duty chain to standard, and are very good, I tried the zvm-x extra heavy duty and it only lasted the same for me so isn't worth the extra (in my experience) JT sprockets are good, not heard of the other one you've been given but there is no issue having different makes front and back! Re: Chain and sprocket question - bellycgb - 27-07-13 (26-07-13, 07:55 PM)elbrownos link Wrote: I've never bought a chain so I'm no expert but a quick google leads me to believe GB means gold & black, not heavy duty. The chain in black and gold never realised that's what the GB part was lol :rollin (26-07-13, 08:45 PM)Punkstig link Wrote: The DID VX is a heavier duty chain to standard, and are very good, I tried the zvm-x extra heavy duty and it only lasted the same for me so isn't worth the extra (in my experience) Cool that's good to know Re: Chain and sprocket question - CharlieDee - 27-07-13 Hope you like cleaning your chain!! As it doesn't stay gold for long!! :grumble mokin
Re: Chain and sprocket question - darrsi - 27-07-13 (27-07-13, 08:20 AM)CharlieDee link Wrote: Hope you like cleaning your chain!! As it doesn't stay gold for long!! :grumble After you've been for a ride and lubed your chain, spray brake cleaner on a rag and rub it over the visible side of the chain, without soaking it, and it'll look like new in no time!
Re: Chain and sprocket question - CharlieDee - 27-07-13 (27-07-13, 09:17 AM)darrsi link Wrote: [quote author=CharlieDee link=topic=9095.msg90747#msg90747 date=1374909627] After you've been for a ride and lubed your chain, spray brake cleaner on a rag and rub it over the visible side of the chain, without soaking it, and it'll look like new in no time! [/quote] Cheers for that Darrsi... I shall give that go!! mokin
Re: Chain and sprocket question - darrsi - 27-07-13 (27-07-13, 09:46 AM)CharlieDee link Wrote: [quote author=darrsi link=topic=9095.msg90754#msg90754 date=1374913043] After you've been for a ride and lubed your chain, spray brake cleaner on a rag and rub it over the visible side of the chain, without soaking it, and it'll look like new in no time! [/quote] You're just cleaning the outer though, so don't soak it enough to get into the rivets otherwise you'll dry it out. Cheers for that Darrsi... I shall give that go!! mokin [/quote] Re: Chain and sprocket question - CharlieDee - 27-07-13 (27-07-13, 09:56 AM)darrsi link Wrote: [quote author=CharlieDee link=topic=9095.msg90762#msg90762 date=1374914768] After you've been for a ride and lubed your chain, spray brake cleaner on a rag and rub it over the visible side of the chain, without soaking it, and it'll look like new in no time! [/quote] You're just cleaning the outer though, so don't soak it enough to get into the rivets otherwise you'll dry it out. Cheers for that Darrsi... I shall give that go!! mokin [/quote] [/quote] Roger D :lol Re: Chain and sprocket question - bellycgb - 28-07-13 The first of many shiny new parts to be fitted. Operation phoenix is GO!
Re: Chain and sprocket question - Punkstig - 28-07-13 WD40 will clean the outer plates with no risk of stripping lubricant like the brake cleaner could! Re: Chain and sprocket question - CharlieDee - 28-07-13 (28-07-13, 09:37 AM)Punkstig link Wrote: WD40 will clean the outer plates with no risk of stripping lubricant like the brake cleaner could! WD 40 is what I tend to use... only prob with it is, it usually attracts dust and crap... well IMO :rolleyes Re: Chain and sprocket question - Punkstig - 28-07-13 (28-07-13, 11:07 AM)CharlieDee link Wrote: [quote author=Punkstig link=topic=9095.msg90970#msg90970 date=1375000641] WD 40 is what I tend to use... only prob with it is, it usually attracts dust and crap... well IMO :rolleyes [/quote] It leaves a coating on anything which attracts all kinds of crud, but then cleans off easily again, we're talking about a chain here, IMO its supposed to look black and oily! Re: Chain and sprocket question - darrsi - 28-07-13 (28-07-13, 01:11 PM)Punkstig link Wrote: [quote author=CharlieDee link=topic=9095.msg90976#msg90976 date=1375006074] WD 40 is what I tend to use... only prob with it is, it usually attracts dust and crap... well IMO :rolleyes [/quote] It leaves a coating on anything which attracts all kinds of crud, but then cleans off easily again, we're talking about a chain here, IMO its supposed to look black and oily! [/quote] But gold is pretty
Re: Chain and sprocket question - Dead Eye - 28-07-13 (28-07-13, 01:11 PM)Punkstig link Wrote: [quote author=CharlieDee link=topic=9095.msg90976#msg90976 date=1375006074] WD 40 is what I tend to use... only prob with it is, it usually attracts dust and crap... well IMO :rolleyes [/quote] It leaves a coating on anything which attracts all kinds of crud, but then cleans off easily again, we're talking about a chain here, IMO its supposed to look black and oily! [/quote] Pretty much my mind set as well Just keep mine topped up with lube and clean it when it gets a bit too pastey
Re: Chain and sprocket question - Lawrence - 06-08-13 (28-07-13, 01:11 PM)Punkstig link Wrote: [quote author=CharlieDee link=topic=9095.msg90976#msg90976 date=1375006074] WD 40 is what I tend to use... only prob with it is, it usually attracts dust and crap... well IMO :rolleyes [/quote] It leaves a coating on anything which attracts all kinds of crud, but then cleans off easily again, we're talking about a chain here, IMO its supposed to look black and oily! [/quote]The entire left side of my swingarm is black, let alone the chain :look
Re: Chain and sprocket question - BluprintZ - 09-08-13 Took the sprocket cover off mine yesterday, been getting noises and vibes through the footrests that pointed to a possible worn chain and sprockets, plus i was rather paranoid about the sprocket nut loosening problem. Happy days, the sprocket nut is tight but both the chain and sprockets are due for replacement, boo! Cleaned all the crap out of the cover and around the sprocket, discarded the cover gasket, which was in bits anyway and re-fitted the cover and made the necessary adjustment to the clutch to compensate for the missing gasket. My chain cleaning routine has usually been a case of cleaning the chain with WD40, then wiping the excess off with a rag, then using a paintbrush to grease the chain with LM grease, i really don't like the spray type chain lubes, maybe i'm just old fashioned? Anyway, just about to order the 12mm front sprocket nut and tab washer and a new chain and sprocket kit. G ; ) |
