Bringing the foxeye back from the dead - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Bringing the foxeye back from the dead (/showthread.php?tid=64527) Pages:
Bringing the foxeye back from the dead - bellycgb - 18-07-13 Hi all its been a VERY long time since i posted here. good to see FOC-U is still going strong ![]() i will take it to a proper mechanic but anything i can do will be awesome. so i guess the first thing i should do is cut the chain off as its past the point of being usable. see if i can somehow release the brakes and flush the tank. guess the carbs will need cleaning too? any advice of what to look for and tips would be great. will post some pictures later Re: Bringing the foxeye back from the dead - simonm - 18-07-13 If you're happy taking the rear wheel off you could leave the chain in oil for a week or so and give it a degrease etc ? Whilst you have the wheel off you can check the pads, give the calipers the once over. Change the oil, check the brake oil levels. TBH my bike was sitting around for 3-4 years before it was passed on to me and bar a seized rear caliper it was good to go until I got my hands on it and dropped it. The most important things imo are tyres, brakes, oil's, chain, lights. The fuel might be old, but if it gets you to the petrol station a fill up should fix that. Just my 2p, E&OE & YMMV Re: Bringing the foxeye back from the dead - Dead Eye - 18-07-13 Welcome back! In regards to the carbs, a clean couldn't hurt but usually any fuel in them evaporates so I would expect them to be bone dry. If they were kept clean and maintained before hand then they should be ok ![]() It would also probably be best to check the battery - it may well have gone flat and there is potential for needing a new one... Flushing the tank is a good idea - old fuel sat for that long will have degraded and you may well have a bit of rust / crap in the tank that you really don't want to get sucked through! Re: Bringing the foxeye back from the dead - simonm - 18-07-13 (18-07-13, 10:24 AM)Dead Eye link Wrote: Flushing the tank is a good idea - old fuel sat for that long will have degraded and you may well have a bit of rust / crap in the tank that you really don't want to get sucked through! :lol . Nothing that being exploded in a combustion chamber won't fix ![]() Re: Bringing the foxeye back from the dead - bellycgb - 18-07-13 thanks for the input guys really loved my fazer and such a shame its got into such a state. but kids and work meant a car was needed and hence the neglect.just gonna work my way through the service interval sections in the haynes manual and try to do as much as i can. it was always properly maintained before i stopped using it. Re: Bringing the foxeye back from the dead - nick crisp - 18-07-13 http://www.sterndrives.com/old_fuel.html Other sites give similar information, so best to drain that old fuel out. A chain that is rusted to your description is never going to be recovered by any amount of soaking/re-lubing, so that has to go too. Check tyres for signs of cracking/deterioration too. Re: Bringing the foxeye back from the dead - darrsi - 18-07-13 (18-07-13, 10:27 AM)simonm link Wrote: [quote author=Dead Eye link=topic=8906.msg88529#msg88529 date=1374139482] :lol . Nothing that being exploded in a combustion chamber won't fix ![]() [/quote] Someone needs to change their fuel filter :lol Re: Bringing the foxeye back from the dead - Dead Eye - 18-07-13 Apparently so ![]() Won't be much of a filter left after if tries to process what's left in the tank Re: Bringing the foxeye back from the dead - darrsi - 18-07-13 (18-07-13, 11:35 AM)Dead Eye link Wrote: Apparently so That was aimed more at simonm, if he wasn't sure it was there then it hasn't been changed for a while ![]() Easy job though.......once he finds it :lol Re: Bringing the foxeye back from the dead - Dead Eye - 18-07-13 Yeah, I know it was, my response was kind of split between the two but wasn't overly clear, sorry ![]() Re: Bringing the foxeye back from the dead - simonm - 18-07-13 What does a dirty fuel filter look like ? I've never seen a fuel filter that looks anything other than cleanish. Re: Bringing the foxeye back from the dead - bellycgb - 18-07-13 well some progress, managed to get the brakes off, so at least its rolling. first thing i need to do is get it outside and pressure wash the tons of crap and cobwebs off. got a charger connected to the battery but i doubt the battery is any good after all these years. the chain is very rusty but not solid like i first thought. maybe a soak in oil will make it usable for a little while until i can change it. the rear brake caliper is stuck, i need to part the pads to get it off the disc how can i do that? Re: Bringing the foxeye back from the dead - darrsi - 18-07-13 (18-07-13, 12:22 PM)bellycgb link Wrote: well some progress, managed to get the brakes off, so at least its rolling. first thing i need to do is get it outside and pressure wash the tons of crap and cobwebs off. got a charger connected to the battery but i doubt the battery is any good after all these years. the chain is very rusty but not solid like i first thought. maybe a soak in oil will make it usable for a little while until i can change it. the rear brake caliper is stuck, i need to part the pads to get it off the disc how can i do that? I seriously don't recommend using a pressure washer on bikes, they cause all sorts of problems like blasting paint off and getting water into electrics. I used one the other day on my engine before a spray job and was amazed how much paint it blew off. A few weeks before that i used a hose with a fine spray and my air horn started screeching for three days to the point that i bought a new one, then it dried out and worked okay :\ I'll be amazed if you can get your chain into a decent working state, it will have sticky links all over it. As for the rear pads, i reckon once the pad pins are removed then a bit of brute force with a pair of pliers will be needed to slide them out. Re: Bringing the foxeye back from the dead - darrsi - 18-07-13 (18-07-13, 12:05 PM)simonm link Wrote: What does a dirty fuel filter look like ? I've never seen a fuel filter that looks anything other than cleanish. It's all internal, so you won't know what's going on inside, but they're only a few quid so if you've never changed it just do it anyway and make a note of the date you changed it ![]() Re: Bringing the foxeye back from the dead - bellycgb - 18-07-13 to be honest there isn't much paint left on the engine anyway lol its all flaking off with a white powdery substance underneath. but yes a hose is a better idea ![]() Re: Bringing the foxeye back from the dead - darrsi - 18-07-13 (18-07-13, 12:50 PM)bellycgb link Wrote: to be honest there isn't much paint left on the engine anyway lol its all flaking off with a white powdery substance underneath. but yes a hose is a better idea Look at the inner paint on my engine, that was caused by jet washing!! http://foc-u.co.uk/index.php/topic,8354.msg82143.html#msg82143 Re: Bringing the foxeye back from the dead - bellycgb - 18-07-13 (18-07-13, 01:03 PM)darrsi link Wrote: [quote author=bellycgb link=topic=8906.msg88564#msg88564 date=1374148205] Look at the inner paint on my engine, that was caused by jet washing!! http://foc-u.co.uk/index.php/topic,8354.msg82143.html#msg82143 [/quote] holy cow looks fantastic ![]() Re: Bringing the foxeye back from the dead - darrsi - 18-07-13 (18-07-13, 01:40 PM)bellycgb link Wrote: [quote author=darrsi link=topic=8906.msg88565#msg88565 date=1374148987] Look at the inner paint on my engine, that was caused by jet washing!! http://foc-u.co.uk/index.php/topic,8354.msg82143.html#msg82143 [/quote] holy cow looks fantastic ![]() [/quote] I have my mate to thank for that, he did a very good job :thumbup Re: Bringing the foxeye back from the dead - bellycgb - 18-07-13 this is the state its in... https://www.dropbox.com/s/0ifbealrirzmh4c/2013-07-18%2013.44.28.jpg https://www.dropbox.com/s/xd0wl3anu9m2wgz/2013-07-18%2013.44.55.jpg rear brake... https://www.dropbox.com/s/nynxy7327jke43g/2013-07-18%2013.45.38.jpg https://www.dropbox.com/s/68f5gojqp6cva8o/2013-07-18%2013.45.48.jpg Re: Bringing the foxeye back from the dead - Dead Eye - 18-07-13 My rear probably looked just as bad before I serviced it so it should be rescuable ![]() |
