air box mods ? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: air box mods ? (/showthread.php?tid=64493) |
air box mods ? - Enceladus - 16-07-13 have replaced the standard filter with a K&N and this got me thinking...... are there any mods to the airbox that anyone has done to improve / increase airflow? had a play with my cage airbox and it now works (breathes) much easier. just wondering if it was possible to do anything with the fazer ? Re: air box mods ? - nick crisp - 16-07-13 Bearing in mind that before you go hacking away at the airbox, the manufacturer has spent considerable time and effort to get the airflow right for the standard bike, so anything you do needs to be a proven improvement. What about the traditional route of pod filters (K&N, S&B) with a Dynojet kit? Re: air box mods ? - Dead Eye - 16-07-13 I haven't known anyone to do anything to the FZS600 airbox - it's a pretty stable design and modifying won't give you many benefits. You'd be better off looking in to what nick crisp has said and remove the airbox all together and fit pod / cone filters to each air carb inlet - I think someone on here threw up a picture of their setup but I have no idea who or what thread, sorry
Re: air box mods ? - Enceladus - 16-07-13 wasn't planning to start butchering the air box. just had a thought pop into my head so i thought i'd ask like the idea of a filter for each carb thoughÂ
Re: air box mods ? - nick crisp - 16-07-13 Cone type filters will require rejetting the carbs to match the increased airflow. On some bikes you can get away with just going up several sizes on the main jets, fine tuning might require raising the needles a notch or two etc. Dynojet kits come with all the necessary bits and instructions and there are shops out there that can do it for you, but choose someone with experience of doing this if you want to get your set-up right. Re: air box mods ? - stevierst - 16-07-13 I think its been mentioned on here before about the individual carb foam filters, and a couple have done it. I think they look and sound ace! Loads of throaty intake roar! The Fazer airbox is apparently a good design from what I've heard. Its mostly bikes sub 10 years old where they've had to design in sound dampening characteristics, thus restrictions to flow and sapping a couple of horses. My Tiger 1050 had a pretty large airbox restriction, and my fz1 airbox was crap until I modded them both. The intake roar went pretty loud on both! Re: air box mods ? - bozboz - 16-07-13 I cut down the inside of the airbox 'cap' the part that holds down the airfilter in place. With a Pipercross filter in place I've notice no adverse effects, just more response (most likely due to the filter but hopefully its helped the engine breath also!). |
