Speedo sensor question- - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Speedo sensor question- (/showthread.php?tid=64450) |
Speedo sensor question- - Punkstig - 14-07-13 Before I go and break something does the the tube with the tabs from the speedo sensor that locates into the wheel just pull out? I realise the thing runs off magnets so last time it was off and I pulled on it gently it wanted to come out but obviously there was resistance- is this from the magnets or is it connected to something to stop it pulling out? Re: Speedo sensor question- - stevierst - 14-07-13 Yep, it just pulls off once the wheel is removed. Re: Speedo sensor question- - Dead Eye - 15-07-13 Probably a bit of resistance from the magnets and any lube / grease as well - should just pull out easy enough. Pretty sure mine just falls out of its own accord when removing the front wheel |
