Oil light, which wire? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Oil light, which wire? (/showthread.php?tid=64445) |
Oil light, which wire? - reillypadraig - 14-07-13 Just wondering if anyone knows which exact wire it is for the oil light in the main white junction under the tank, Ill explain, simply I was removing the whole from fairing and the whole lot sometime ago now, but I did plug out the wire in the junction box under the tank to remove the clocks completely, when I plugged all back together I lost indicators lights dash lights fuel light, so checked the big white connector and its corroded to hell inside, half the little needles are broken or gone, so I put it back together and tightened it with a cable tie and low and behold everything works, except the oil light, Just wondering without having to bollox round tracing wires tru the frame and loom does anyone know the exact wire? Re: Oil light, which wire? - clayt74 - 15-07-13 looks to me like its the Black and Red wire that is towards the middle of the connector on the bottom row. good luck Re: Oil light, which wire? - reillypadraig - 15-07-13 Thanks! If I can find the adjacent wire on the far side that its meeting and get a long straight connector it should work, one way to find out is just hit the kill switch and press starter button eh? |
