fazer 1000 ( 2001 ) gearbox fault - Please HELP - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: fazer 1000 ( 2001 ) gearbox fault - Please HELP (/showthread.php?tid=64349) |
fazer 1000 ( 2001 ) gearbox fault - Please HELP - fazerderek - 08-07-13 I have a 2001 fazer 1000 with 44k on the clock It developed a clattering noise that stopped upon selecting a gear I have removed complete clutch assembly back to the oil pump chain and found the gearbox input shaft has about 1/8th of a turn free play I have been told this is the fault but without removing anymore i was hoping someone might know what is wrong to cause this fault Can anyone help in my plight to fix my bike - Thanks in advance . Fazerderek. Re: fazer 1000 ( 2001 ) gearbox fault - Please HELP - fazerderek - 08-07-13 hope modifying my post helps Re: fazer 1000 ( 2001 ) gearbox fault - Please HELP - sadlonelygit - 08-07-13 gen 1's can have problems with the selector forks due to cack handed 2-3 gearshifts on the back wheel. also a possibility of a broken return spring in the selector area. if the bike is in gear, you will have some backlash as the teeth mesh, check for up/down/left/right play in the shaft rather than rotational play. did the noise go away with the clutch pulled in, or only on gear selection, that should tell you where the problem is! but to save you the hassle i'll give you £100 for ii as a non runner
Re: fazer 1000 ( 2001 ) gearbox fault - Please HELP - fazerderek - 08-07-13 Thanks for the info Wow a £100 - that much Thanks for the insulting offer but NO Re: fazer 1000 ( 2001 ) gearbox fault - Please HELP - fazerderek - 09-07-13 i was at the meeting at Birmingham classic bike museum with a friend on his thunderace Re: fazer 1000 ( 2001 ) gearbox fault - Please HELP - fazerderek - 09-07-13 I have found a local guy who will strip and rebuild my gearbox to former glory so looking like i will be sorted in the near future at a minimum cost to my pocket I have owned this bike for 6.5 years and its the first major engine issue ( not including ex-up valve problems ) Re: fazer 1000 ( 2001 ) gearbox fault - Please HELP - andybesy - 09-07-13 Let us know how you get on, and in particular what the problem turns out to be. Re: fazer 1000 ( 2001 ) gearbox fault - Please HELP - fazerderek - 17-08-13 Gearbox fault fixed 1st gear pinion/bush and output shaft was shot I still have rest of the box if anyone needs any spares ( on the cheap ) |
