pass light turns clocks off/on - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: pass light turns clocks off/on (/showthread.php?tid=64221) |
pass light turns clocks off/on - ajmes1 - 30-06-13 Just been tinkering around my FZS600 this afternoon attempting to source the problem for the fuel gauge not working, and noticed that when the ignition is on without the engine running, as I click the pass switch the clocks switch off and then immediately come on again through their start up sequence. Any body else have this problem? Could it be related to the fuel gauge not working correctly (see other post further down), or indicative of a dodgy battery? James Re: pass light turns clocks off/on - Ruby Racing - 30-06-13 Is your battery fit and healthy? Could be on the way out and when you hit the pass button what power is left goes to the lights and takes away from the instruments. Just a thought. Re: pass light turns clocks off/on - ajmes1 - 30-06-13 As far as I know, I only bought the bike a couple of weeks ago from a dealer, so it may not be. with the ignition off, the battery reads 12v. With the ignition on (engine off) and put under load from the pass light switch, the battery gives a reading of 11v. Is that normal or would it maybe need a charge/replacing? Re: pass light turns clocks off/on - Soapy - 30-06-13 (30-06-13, 06:56 PM)ajmes1 link Wrote: As far as I know, A good battery off load should be at least 12.5v. After a good run or charge mine reads 12.8v. See what it drops to when you hit the starter. My battery last year gave me no warning when it failed. I started it as normal and went to get petrol. Came out after paying and when I went to start it, nothing. Wouldn't even bump. Had to push it a mile home. I put a meter across the battery and pressed the starter, nothing and the battery dropped to 9v. Just to make sure it was a duff battery I jumped it off the car and she started straight away. Lifted revs to 3500 and battery voltage was 13.5v so charging system ok. Bought new battery. Problem sorted. Re: pass light turns clocks off/on - Ruby Racing - 30-06-13 Sounds a bit low. Put it on charge and see how you go. However a battery can still read good volts but still be knackered. If you can try a battery you know is good that will help diagnose it. On later fuel injected bikes with lots of electronics a bike wont start unless the battery is above a certain level as the ECU knows it needs a certain amount of juice to make everything work. That's why you can't start them by bumping either, the ECU wont allow it. However the Fazer is not fuel injected and doesn't have loads of electronics, but it could still be susceptible to a low battery. If it's the original battery and it's an old bike then it may be time for a new one. Just try and find out if it's OK first. If it's shot then try and get a free one out of the shop you bought it from. A poor battery can cause quite a few problems. Re: pass light turns clocks off/on - ajmes1 - 30-06-13 Thanks for the advice, 12/11v with no load. With the starter motor it drops to 10v (multimeter doesn't do decimals unfortunately). As you said, revving the engine increases the voltage to 13 so charging system is working. i'll give it an overnight charge, and if that doesn't work i'll have a word with the dealer i got it from Sorry for what seems like daft questions, I haven't really had to do this before!! but thanks for all the brilliant advice Re: pass light turns clocks off/on - Ruby Racing - 30-06-13 It's not a daft question if you don't know the answer. I don't know the answer either, just throwing out some suggestions. Had a few dealings with batteries and R/R's as I have a 2006 Triumph Daytona 675 and batteries and R/R's are their biggest problems. Re: pass light turns clocks off/on - ajmes1 - 01-07-13 Cheers again! After a charge, nothing seems to have improved. Same readings off the multimeter (drops to 10v with starter, 11v with pass light load). I'll try hunting down a good battery then try again, unless theres any other ideas from people? James Re: pass light turns clocks off/on - darrsi - 01-07-13 Pretty much sounds like the battery's had it. As you've only just bought it you don't know how long the bike's been sitting around for? Lead acid batteries prefer a constant regular charge, if it's been sitting idle for months, especially in cold weather, then they simply don't like it. Personally i'd be looking at getting a Yuasa replacement if you need one. Re: pass light turns clocks off/on - clayt74 - 01-07-13 Most dealers fit a new battery as a matter of course when you buy a bike from them. I would push for a free new replacement from where you bought it from! Re: pass light turns clocks off/on - darrsi - 01-07-13 (01-07-13, 05:16 PM)clayt74 link Wrote: Most dealers fit a new battery as a matter of course when you buy a bike from them. Yeah, good shout...... |
