How the hell do you remove the Cambox Cover ??? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: How the hell do you remove the Cambox Cover ??? (/showthread.php?tid=64218) |
How the hell do you remove the Cambox Cover ??? - YamFazMan - 30-06-13 Hi I'm about to check the valve clearances 24000 mile service, All the bolts removed, Cambox Cover loose But How the hell do you remove it from the bike ???. ATB YFM Re: How the hell do you remove the Cambox Cover ??? - Punkstig - 30-06-13 Unless you're having problems with the bike running don't even bother checking them at 24000, both my fazer and thundercat were run past 120,000 without them being done! Re: How the hell do you remove the Cambox Cover ??? - His Dudeness - 30-06-13 You might have to remove the bolt holding the thermostat in and wiggle it out of the way to get a bit more room Re: How the hell do you remove the Cambox Cover ??? - YamFazMan - 30-06-13 Hi Thanks for the reply's I tried the thermostat bolt "No joy" so I held the cover open with a small block of wood under each corner and checked the clearances like a gynaecologist All the clearances were in-spec Thanks again ATB YFM Re: How the hell do you remove the Cambox Cover ??? - His Dudeness - 30-06-13 Well done. Didn't know gynaecologists used blocks of wood :lol |
