What grease? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: What grease? (/showthread.php?tid=64215) |
What grease? - Farjo - 30-06-13 Centre stand is no longer smooth and gets stuck half-way up and needs to be lifted by hand. So I want to take it off to clean and grease it. Having had no spanner experience before biking I need to ask what grease to use. There seems to be many mentioned on an internet search - lithium, white, or mostly just "grease". I already have copper grease - is this good for the job or should I get something else? And finally is this a job I can do myself - have read darsi's thread http://foc-u.co.uk/index.php/topic,2879.0.html however I would suggest that there is a gap between his years of experience and expertise and my own
Re: What grease? - Fazerider - 30-06-13 I hope yours comes off easier than mine. My centrestand has been getting harder to use lately as it's developed a twist... it was fight to get the r/h bolt undone, had to take the angle grinder to the rounded-off locknut in the end. Grease: main requirement there is something really thick that's going to stay put. I use Castrol Heavy. Re: What grease? - simonm - 30-06-13 I'm not altogether positive you need to take the stand off to do what you want. Clean all the gunk off, use a degreaser, move it through it's entire range of movement. A different bike, but you might learn some useful info on this page http://www.motorcycleinfo.co.uk/index.cfm?fa=contentGeneric.qgntgwplktwyjcps&pageId=2214557 But in answer to your question, I am sure copper grease will be fine, just don't put much on. http://fazerowners.yuku.com/topic/26806#.UdAdm_msiSo http://foc-u.co.uk/index.php?topic=6868.0 http://www.bikerforum.co.uk/topic/8355-centre-stand-spring/page__view__findpost__p__85378 Re: What grease? - bandit - 30-06-13 Try lubricating with engine oil if you want to use grease lithium/general purpose or molydisulphide. Re: What grease? - andybesy - 30-06-13 Some lithium grease should do the job, you can usually pick up some cheap stuff from the pound shop. Andy Re: What grease? - Dead Eye - 30-06-13 I'd probably go with lithium grease as well - seems a bit more resistant to water / muck than copper. I use copper on bolt threads to prevent corrosion more than anything else Re: What grease? - darrsi - 30-06-13 I could be very wrong but the reason it may be sticking might be because the stand is twisted, they have a bad habit of doing that? As suggested i would degrease the joints first with brake cleaner, or whatever you have, and see if it helps at all. Then a heavy lithium grease is what i'd also use. Don't bother with copper grease, that's used more to stop metals bonding together, rather than a moving parts lubricant. Re: What grease? - Punkstig - 30-06-13 (30-06-13, 03:43 PM)darrsi link Wrote: Don't bother with copper grease, that's used more to stop metals bonding together, rather than a moving parts lubricant. Yep, only use copper grease on nuts and bolts so they don't get stuck, normal grease on moving parts. Tbh I wouldn't be too concerned about what type (lithiumetc) just greasing its going to be better than no grease at all! Re: What grease? - nick crisp - 30-06-13 Looking on 1000s corner, twisted stand seems to be a prelude to the thing breaking altogether, dumping the bike on the floor. If you're taking it off, might be a good idea to check that it's not cracked. Don't know if this has been a problem on the 6's? Re: What grease? - darrsi - 30-06-13 (30-06-13, 05:22 PM)nick crisp link Wrote: Looking on 1000s corner, twisted stand seems to be a prelude to the thing breaking altogether, dumping the bike on the floor. If you're taking it off, might be a good idea to check that it's not cracked. Don't know if this has been a problem on the 6's? Yeah, they start with a bit of rust first, then twist. Re: What grease? - Farjo - 30-06-13 A big thanks for all the replies :thumbup I think I'll leave it in place for now but try to clean it with chain cleaner and lube it with engine oil, see what that does. Re: What grease? - JZS 600 - 30-06-13 I've got some white spray grease that does the job. Came from the WD 40 range that they brought out a while ago but does the job, even if it splatters a bit. Re: What grease? - JZS 600 - 30-06-13 http://www.audiomate.co.uk/proddetail.php?prod=WD1020&gclid=CMnnle2-jLgCFWzItAod22gADA That's the bugger! Got some of their de-greasant as well that does the job too... Re: What grease? - Doddsie - 30-06-13 Noticed mine was sticking yesterday (dont use the main stand much) I just gave it a few squirts of 3in1 oil and its fine again now!! Re: What grease? - Dave48 - 30-06-13 When my centre stand twisted it was due to severe corrosion of curved tubular bridge section which has been cut out & a new piece welded in, restoring shape & strength If you can remove the stand bolts/nuts the shouldered part of the bolt dries out and gets rusty. Clean off & use lithium based grease on reassembly. Otherwise spray grease with "straw" attachment into the parts between stand & frame bearers. Double check springs ok-they do wear out intime. Re: What grease? - darrsi - 01-07-13 That tub would last me 20 years! Re: What grease? - unfazed - 01-07-13 (30-06-13, 12:42 PM)Farjo link Wrote: Centre stand is no longer smooth and gets stuck half-way up and needs to be lifted by hand. So I want to take it off to clean and grease it.Spray WD40 liberally on the spring and around the 2 bolts attaching it to the frame. Move it up and down to see if it frees out. If so it just needs greasing. I usually use good quality chain grease and it works fine. Worst case scenario is that it is starting to crack and needs to be replaced. Not a difficult job just awkward to get at. Re: What grease? - Slaninar - 01-07-13 I use some spray lubricant. I believe it is mixture of teflon (PTFE, whatever they call it) and lithium soap base lubricant. Easy to just spray beneath the bike. If you want to be thorough: 1st some degreaser, then wash it off, then some WD40. Let it drip. Then apply some grease and spray lubricant. I got cheap some red "coplex lithium grease". It is very good. This explains advantages: http://www.machinerylubrication.com/Read/28381/grease-lithium-production-resistance The complex grease doesn't get more gummy in cold than the regular one, at least it appears that way. When in doubt: Elastica - Vaseline |
