MOT question - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: MOT question (/showthread.php?tid=64209) |
MOT question - ghostbiker - 29-06-13 Playing with a beat up Zx6r and gunna try a mot on it. Done pretty much all the mot work now apart from its front mudguard is smashed. Now with the 1998 Zx6r the front fairing hangs a long way over the wheel. Is a front mudguard a must for mot (got one on way but will be a week or so) or can I get away with out it. Re: MOT question - jon - 29-06-13 Plenty of custom chops and harleys out there with no front muddie, unless they take them off after the mot. Re: MOT question - jon - 29-06-13 And what about dirt bikes? The muddie on them is mounted right up under the front light, about 2 foot away from the actual wheel Re: MOT question - solorider - 29-06-13 looking in the MOT manual there is not a lot mentioned about mudguards except for this Some fork arrangements rely on the bracing incorporated in the mudguard fixings to maintain their alignment. A mudguard insecurely fixed to the forks may therefore adversely affect the handling of the machine Check the security of the front mudguard and look for evidence of it having been in contact with either the wheel, the tyre or any fixed part of the machine. and in the failure section An insecure mudguard or one able to easily contact the wheel, tyre or any fixed point of the machine. Re: MOT question - ghostbiker - 29-06-13 Hmm, as its just plastic and no brace at all think I will try and see if it pass's Just need to get a Reg plate and it should be mot time
Re: MOT question - rustyrider - 30-06-13 Full bike MoT manual is here http://www.motinfo.gov.uk/htdocs/m1i00000001.htm Re: MOT question - jon - 30-06-13 I've got a feeling that they are like lights on a bike and spare wheels in a car. If they are fitted then they have to work properly. If they aint fitted they aint tested (although you get an advisory for lights on a bike not to ride it in anything but perfect visibility - a so called daylight mot). Re: MOT question - robby boy - 30-06-13 Might be worth asking the testing station if he would pass or fail it before putting it in. Re: MOT question - ghostbiker - 30-06-13 I'm working all week so dropped it off tonight. Will see if it passes Tuesday or not. Np if it fails, free retest and new mudguard should be here by the weekend. Mind you it has no Reg plate either but that should be here Tuesday
