Hein Gericke battery optimiser deal - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Hein Gericke battery optimiser deal (/showthread.php?tid=64198) |
Hein Gericke battery optimiser deal - sure2ride - 29-06-13 Go to the HG site to check the specs, but it seems a good one to me. £29.99 (alegedly from £49.99), BUT, when I went to local store to get one (not available on line) I got £10.00 off if I spent more than £30.00. So.....got some chain cleaner which I neded anyway, and effectively got the charger for £19.99. Not Bad....only point to note is that mains connection is via a 2 pin plug so you either need a shaver adapter plug, or I guess you can cut the cable and put an ordinary plug on. ( It does say in instructions that mains cable can be replaced if damaged, so I guess cutting it counts as damage :lol Anyway, I think it seems a good charger and a good price. Check out your local store for availabilty if interested, I phoned mine first and they had plenty. Re: Hein Gericke battery optimiser deal - Fazerider - 29-06-13 Odd... I thought it was a legal requirement for domestic electrical equipment to be sold with the correct plug these days. Re: Hein Gericke battery optimiser deal - stevierst - 29-06-13 Probably why they're so cheap! :
Re: Hein Gericke battery optimiser deal - Andy FZS - 29-06-13 If the charger is double insulated and hence has no earth connection then it is the correct plug, but that not to say you couldn't connect it to a standard 3pin plug and not connect the earth as there will not be one. Re: Hein Gericke battery optimiser deal - Fazerider - 30-06-13 (29-06-13, 08:28 PM)Andy FZS link Wrote: If the charger is double insulated and hence has no earth connection then it is the correct plug, but that not to say you couldn't connect it to a standard 3pin plug and not connect the earth as there will not be one.Class II equipment is not exempt from the UK requirement for having a fused plug that meets BS1363, it still needs an earth pin (doesn't need to be of conducting material) to open the shutters on UK sockets. Pretty sure HG are breaking the law unless the charger was marked with a "not suitable for UK" warning or supplied with an adaptor. Re: Hein Gericke battery optimiser deal - nick crisp - 30-06-13 Don't think that would be a problem as a 3 pin adaptor would probably be fitted with a fuse - can't use it in the UK without one... Re: Hein Gericke battery optimiser deal - Andy FZS - 30-06-13 Selling items with a two pin plug if not is problem if it was then your toothbrush razor etc couldn't be charged and yes I know there fed from a bespoke socket that's isolated from earth etc. Re: Hein Gericke battery optimiser deal - Andy FZS - 30-06-13 Typo......should be is not Re: Hein Gericke battery optimiser deal - sure2ride - 30-06-13 Well I have just checked the packaging, does'nt say it can't be used in UK, and the writing on the packaging is mostly German . Still, I think the charger is a good one for the dosh, and I can easily put a 3 pin plug with a 5amp fuse so I still think it was a good deal for £20 , ...as it is an optimiser rather than a straight charger. Plus...it has some cool lights on it. :lol Might just phone HG head office on Monday just to check if they should have provided an adaptor and see what their response is... just out of interest really Only started this post to let forum know that I thought it was good, but all the comments have been interesting, thanks. Re: Hein Gericke battery optimiser deal - Andy FZS - 30-06-13 It seems toothbrushes etc are exempt and other items are only allowed to use a two pin plug if it is fitted to an adapter and can only be removed with the use of a tool. Others may have a better explanation. Re: Hein Gericke battery optimiser deal - elbrownos - 30-06-13 You need something like this http://www.maplin.co.uk/euro-convertor-white-19246 European appliances sold in the UK usually come with one. Don't buy it from Maplin though. £6.49 is a ripoff Re: Hein Gericke battery optimiser deal - sure2ride - 01-07-13 I phoned Hein Gericke customer services this afternoon, and they told me that the adaptors were in stores and that I should have been given one for free when I bought the optimiser. They will be sending one out in the post today. Top stuff Re: Hein Gericke battery optimiser deal - sure2ride - 08-07-13 UPDATE.....Adapter received in the post today. It's a pukka one that you fit the two pin plug into and then screw the adapter together so that it looks just like an ordinary 3 pin plug. HG still have the deal running, so if you want an optimizer at a really good price (£20 if you use the voucher) then check it out. But make sure you pick the adapter up when you visit the store to buy the item ! |
