NOT FRONT SPROCKET NUT AGAIN - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: NOT FRONT SPROCKET NUT AGAIN (/showthread.php?tid=64161) |
NOT FRONT SPROCKET NUT AGAIN - jason1 - 27-06-13 Hi , KNOW THIS HAS BEEN COVERED, BUT TOOK COVER OFF TODAY TO GIVE A BLOODY GOOD CLEAN AND MEASURED FRONT SPROCKET NUT AND IS ONLY 9MM , IS IT RIGHT NEW UPGRADE IS 12MM? WAS LOOKING FOR THREAD ON HERE FOR BEST PLACE TO GET ONE ( MUST BE BLIND)CAN ANYONE POINT ME IN THE BEST DIRECTION ? HAS BEEN FINE FOR PAST FEW YEARS BUT RATHER CHANGE NOW . CHAIN AND COVER ARE ALL CLEAN AND RE-LUBED UP NOW ;-) Re: NOT FRONT SPROCKET NUT AGAIN - Thorn - 27-06-13 (27-06-13, 05:34 PM)jason1 link Wrote: Hi , KNOW THIS HAS BEEN COVERED, BUT TOOK COVER OFF TODAY TO GIVE A BLOODY GOOD CLEAN AND MEASURED FRONT SPROCKET NUT AND IS ONLY 9MM , IS IT RIGHT NEW UPGRADE IS 12MM? WAS LOOKING FOR THREAD ON HERE FOR BEST PLACE TO GET ONE ( MUST BE BLIND)CAN ANYONE POINT ME IN THE BEST DIRECTION ? HAS BEEN FINE FOR PAST FEW YEARS BUT RATHER CHANGE NOW . CHAIN AND COVER ARE ALL CLEAN AND RE-LUBED UP NOW ;-) WHAT WAS THAT? I CANT HEEEAR YOU Re: NOT FRONT SPROCKET NUT AGAIN - Andy FZS - 27-06-13 Yes moded nut 12mm available from you local dealer. Part number is on here somewhere if you you need it. Andy Re: NOT FRONT SPROCKET NUT AGAIN - andybesy - 27-06-13 Hi Jason, I ordered it online here: http://www.wemoto.com/bikes/yamaha/fzs_600_fazer_sp/02-03/ If you look for "Sprocket Front Retaining Nut Kit (OEM)" you'll see it's described as: "This is the OEM Yamaha Nut and washer kit 90891-10124-00, the later up rated kit for earlier bikes with the troublesome thinner nut." http://www.wemoto.com/bikes/yamaha/fzs_600_fazer_sp/02-03/picture/sprocket_front_retaining_nut_kit_oem/ I'm told you can probably get it for free from your dealer and save a tenner, but another option for you if more convenient and shows part number at least. Andy Re: NOT FRONT SPROCKET NUT AGAIN - Punkstig - 27-06-13 Just over £2 from a dealer with the tab washer included! Re: NOT FRONT SPROCKET NUT AGAIN - jason1 - 27-06-13 Thanks all , ordered
Re: NOT FRONT SPROCKET NUT AGAIN - Jc72 - 27-06-13 What's wrong with the front sprockets then, and does it affect all years? Mines a 2003 fox eye Re: NOT FRONT SPROCKET NUT AGAIN - darrsi - 27-06-13 (27-06-13, 11:28 PM)Jc72 link Wrote: What's wrong with the front sprockets then, and does it affect all years? Mines a 2003 fox eye They either seize/weld themselves on, come loose or just disappear completely. You need to upgrade the 9mm wide nut to a 12mm wide nut and washer kit, part number 90891-10124 Personally i would get it changed next time you renew your chain and sprockets just for peace of mind, or asap if you're the worrying type. Re: NOT FRONT SPROCKET NUT AGAIN - Dave48 - 28-06-13 Its £2-44 exactly from my local Yamaha dealer-pick up. Very small price for peace of mind! Re: NOT FRONT SPROCKET NUT AGAIN - garyb - 14-07-13 Just checked mine after reading this thread and it's not good news, the 9mm nut was loose and only being held on by the tab washer. I tried to tighten it up again but it won't (i.e. it will thread along the shaft fine but it won't fully tighten up at the end) Looks like the thread on the nut is worn and thankfully not the thread on the output shaft. Asides from ordering the new bigger nut is there anything else I can do with this in the short term as a temporary fix? Re: NOT FRONT SPROCKET NUT AGAIN - Punkstig - 14-07-13 Apart from not riding it, not really Re: NOT FRONT SPROCKET NUT AGAIN - darrsi - 14-07-13 It's too dangerous to start attempting any kind of short term fix, and the fact that you now know about it is more than enough to suggest getting it sorted properly. If anything went badly wrong while you were riding it you wouldn't forgive yourself. Re: NOT FRONT SPROCKET NUT AGAIN - garyb - 14-07-13 (14-07-13, 03:45 PM)darrsi link Wrote: It's too dangerous to start attempting any kind of short term fix, and the fact that you now know about it is more than enough to suggest getting it sorted properly. Thanks your right, I'll stick it in the shed until the new nut and tab arrive. |
