A lovely day to be sat at the side of the road ! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: A lovely day to be sat at the side of the road ! (/showthread.php?tid=64159) |
A lovely day to be sat at the side of the road ! - snapper - 27-06-13 Well it had to happen eventually ![]() 2003 gen 1 thou abit strange this one last night I went to check the bike as I haddent used it for a couple of weeks and the battery was flat (just clicling when I hit the starter button) jumped it of aanother battery and she started first time warmed her up left her to run for a good 20 mins , stopper her , no warning lights or rev counter error codes . but still the battery was flat . I left it connected to the other battery overnight and again this morning it was still flat but jump started easily As I pulled away all the lights went out the speedo and rev counter all died ! the only thing working was the multigauge ! but the bike was running fine ! I did a half hour run still nothing every now and then all would burst into life then die again ! stopped the bike and it was still flat ! I went to my appointment and jumped the bike still easily but still no lights or speedo and rev counter ! I road for about five minutes the the bike started to pop bag and slowly dies till it got to tick over speeds at which it ran fine ! I then got to spend a lazy hour and a half waitting to be recovered ! anyway , My thinking is the battery has died but still had a bit of life in it , but is no longer accepting a charge so once the battery power level got so low it could no longer run the bike ? My question is if its why wasnt the charge from the bike alternater keeping it going , ( as yet I havent been able to test to see if it is sending out a charge ) anyone have any other ideas ? some thing I might need to check ? I will check and clean all the connections as well as charge the battery Re: A lovely day to be sat at the side of the road ! - Falcon 269 - 27-06-13 Aside from confirming that the battery will take and hold a full charge, next check this: http://www.yamahafz1oa.com/eskortsdefectiveconnectorreplacement.shtml ![]() Mike Re: A lovely day to be sat at the side of the road ! - JoeRock - 27-06-13 If the battery is THAT flat that it can't hold a charge, your alternator won't be able to run the bike. The bike runs off the battery, so irregardless of how that is being charged if it can't output a decent supply then the bike will conk out. Bit strange that the engine was still running though without the clocks and that on! Re: A lovely day to be sat at the side of the road ! - solorider - 28-06-13 My blackbird did something similar, I fitted a new battery and no problems after, annoyingly the battery wasn't that old,the optimate killed that battery. Re: A lovely day to be sat at the side of the road ! - snapper - 28-06-13 Thanks for the replies Mike I did look at that mod but checked mine last year cleaned it and it did seem fine so left well along The old addage ( if it ant broke don't fix it ) maybe I should now though Solo Mines a fairly new battery , one of the motobats glass mat ones but I don't have power to my garage so I can only connect it to another charged battery with some small jump leads I made ! hopefully this weekend I will get a chance to have a route around clean and check the bits and bobs and try charging the battery need to fine a electrical tester as well Re: A lovely day to be sat at the side of the road ! - fazer-rat - 28-06-13 (28-06-13, 10:35 AM)solorider link Wrote: My blackbird did something similar, I fitted a new battery and no problems after, annoyingly the battery wasn't that old,the optimate killed that battery.glad its not just me,, used to charge my batteries once a month,, then plugged an optimate in and totally killed the battery best thing is to take it off the bike when parking it up. Re: A lovely day to be sat at the side of the road ! - AdieR - 29-06-13 Get your battery "load-tested" (a load test is NOT a voltage test). Reg / rec is worth checking too (bear in mind a failed r/r can take a battery with it). Re: A lovely day to be sat at the side of the road ! - CRH - 29-06-13 (29-06-13, 02:23 AM)AdieR link Wrote: Get your battery "load-tested" (a load test is NOT a voltage test).....yep defo chk the reg/rectifier my mate had a very similar prob with his bandit 12 replaced battery and still did it 2wks later and that ended up being a very green" plug connector to the reg/rec, but he put a new one on anyway!!
