broke down - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: broke down (/showthread.php?tid=64153) |
broke down - rjd1 - 26-06-13 out on my 53 plate 1000cc the night, after putting it on the road filled it with fresh fuel, went a run done about 90 mile all fine, then on overrun it popped 3 or 4 times back though exhaust, then cut out checked all conections all seemed fine,let it sit for a bit tried again it started but as soon as you try to rev it cuts out any common faults, sticky floats?? Re: broke down - unfazed - 27-06-13 Check the fuel filter and pump Re: broke down - rjd1 - 27-06-13 does it prime every time ignition switched on canny mind Re: broke down - Falcon 269 - 27-06-13 Will it take a small amount of throttle, if you're careful? Define 'putting it on the road'. Has it been laid up for a while (how long?) and did you do anything else apart from adding fresh fuel? Re: broke down - PaulSmith - 27-06-13 Did you forget to close the choke? Re: broke down - rjd1 - 27-06-13 it aint been out since last june I`d done 70-80 mile with fresh fuel an choke of before this happened is throttle position sensor the culprit as some sites say I`d had the front r1 forks off an back on that's it kill switch cant be problem as it wont turn over when switched same with side stand switch Re: broke down - snapper - 27-06-13 well I have just join you on this the first time ever broken down at the side of the road ! battery was dead no charge Re: broke down - Falcon 269 - 27-06-13 If it's been standing for a year, my first thought is the carbs and the rest of the fuel system will need checking and cleaning. Check also that the battery is 100% charged and shows 12.5 - 12.7v across the terminals with the ignition on. Shoot some electrical contact cleaner through all the switch gear and the body of the ignition switch. Flush out any gunk which might have built up in there. Have a read of this and check yours, too: http://www.yamahafz1oa.com/eskortsdefectiveconnectorreplacement.shtml TPS failures are rare and you'd expect to get a 3k error code on the tacho. Assume nothing is OK without actually checking it. When you have it fixed, don't leave it a year between rides again. ![]() Good luck, Mike Re: broke down - rjd1 - 03-07-13 well finaly got a chance to get stuck in about fazer the night cleaned every plug kept checking if it would start nothing had tps off all fine same with kill switch and side stand switch, wanted to rule everything out found by chance that ingnition switch was loose on further inspection noticed it had started to separate took it off the bike altogether, and internal bolt`s had worked loose, so drilled out top of shear bolts to remove shroud,removed internal bolt`s threadlocked them refited,used small allen type bolts for now plugged back in and it burst into life does anyone no whare I can get shear bolts? Re: broke down - rjd1 - 03-07-13 road tested an happy bunny again
Re: broke down - Falcon 269 - 03-07-13 Excellent! Well done.
