Spark plugs CR8E vs CR9E - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Spark plugs CR8E vs CR9E (/showthread.php?tid=64065) |
Spark plugs CR8E vs CR9E - Slaninar - 22-06-13 What are the differences? Which ones to pick? Hmm? Re: Spark plugs CR8E vs CR9E - darrsi - 22-06-13 http://www.ngksparkplugs.com/techinfo/spark_plugs/partnumberkey.pdf Re: Spark plugs CR8E vs CR9E - unfazed - 22-06-13 The 8 is what is called a hotter plug and recommended for the cooler climate of northern Europe. The 9 is a colder plug and recommended for the warmer climate of southern Europe. The colder plugs conduct the heat away from the plug faster than the hotter plugs. Cr8e is the recommended plug for UK and Ireland Re: Spark plugs CR8E vs CR9E - darrsi - 23-06-13 Serbia? Re: Spark plugs CR8E vs CR9E - unfazed - 23-06-13 Easy answer, Southern Europe, CR9E Re: Spark plugs CR8E vs CR9E - dBfazer600 - 23-06-13 Its a question that is subjective upon your climate and needs with the looks of things by the responses but the following may help you in your choice. Daz http://foc-u.co.uk/index.php?action=downloads;sa=view;down=48 Re: Spark plugs CR8E vs CR9E - Thorn - 23-06-13 Ignoring the temperature benefits, I wonder if there's a marked performance difference? Re: Spark plugs CR8E vs CR9E - unfazed - 23-06-13 Short answer NO. Never noticed a difference in the 8 and 9, but did notice an improvement using the EIX over the standard E versions Re: Spark plugs CR8E vs CR9E - Thorn - 23-06-13 Interesting, well I have some CR9EIX's brand new sitting unused, I'll chuck those in with the rebuild then
Re: Spark plugs CR8E vs CR9E - Slaninar - 24-06-13 I'm in "Central Europe" officially. CR9E run a bit darker than perfect - like mixture is bad, or plugs are too cold. Guess CR8E would be better. I've used CR8E until now, but this winter mechanic put CR9E (even though I told him to put CR8E). Guess he thought 9s are better for our climate. 36 degrees celsious here last week. |
