rear wheel bearings - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: rear wheel bearings (/showthread.php?tid=64048) |
rear wheel bearings - justy1 - 21-06-13 been told the rear wheel bearings need changing at some point. any recommendations on what ones are best/most popular? bikes a T reg mk1. many thanks justy1000 Re: rear wheel bearings - otis - 21-06-13 If you can find a bearing wholesaler in your area you will get better quality bearings and a hell of a lot cheaper. I always use the 2 or 3 in my area every time and most are of the shelf. Any of the Jap makes are bang on Re: rear wheel bearings - JZS 600 - 21-06-13 Fiver each on Wemoto or get the bearing code and go for SKF Re: rear wheel bearings - stevierst - 21-06-13 Yep, take the old bearing into a wholesales bearing place, and get one from the experts! Re: rear wheel bearings - JZS 600 - 21-06-13 http://www.timken.co.uk/en-US/about/NewsRoom/Stories/Pages/LaunchesAwarenessCampaignAgainstProductCounterfeiting.aspx Oh yes, there is a World Bearing Association More bearings, Norma? :lol Re: rear wheel bearings - His Dudeness - 22-06-13 The original ones in the front are koyo so I presume the rear are the same but skf, fag are top quality too Re: rear wheel bearings - darrsi - 22-06-13 (21-06-13, 06:33 PM)JZS 600 link Wrote: http://www.timken.co.uk/en-US/about/NewsRoom/Stories/Pages/LaunchesAwarenessCampaignAgainstProductCounterfeiting.aspx These very important people help the world go round :rollin :rollin :rollin Re: rear wheel bearings - Biggy461 - 22-06-13 I got mine from WeMoto for about £35 I think for all of them front, rear and sproket and seals. Delivered quick as well - no issues yet. Re: rear wheel bearings - stevierst - 22-06-13 (22-06-13, 09:50 AM)darrsi link Wrote: [quote author=JZS 600 link=topic=8427.msg83021#msg83021 date=1371836003] These very important people help the world go round :rollin :rollin :rollin [/quote] Darsi, get your coat!!! :fish :rollin :rollin Re: rear wheel bearings - JZS 600 - 22-06-13 I'll see you around (boom boom!) Re: rear wheel bearings - justy1 - 26-06-13 cheers guys. always buy my bearings from the local bearing dealer. just wanted to know what the best/most commonly used bearings were as this is the 1st time ive had to change um. anyone know the code as i cant really take um out as the bikes my only mode of transport. :\ thanks again. justy1000 Re: rear wheel bearings - red98 - 26-06-13 had a full set once.....lost a few now though :lol Re: rear wheel bearings - gassitt - 26-06-13 Rear wheel 6204 2RS Sprocket carrier 6206 2RS And the best ones are the ones I get free from the stores at work
Re: rear wheel bearings - unfazed - 26-06-13 The Fzs 600 bearings are: Front Wheel 6203-2RS CN or C3 Rear Wheel 6204 - 2RS CN or C3 Sprocket Carrier 6206 - 2RS CN or C3 RS is for rubber seals an CN is Clearance Normal and C3 is Clearnce Code 3 The clearance is measured between the balls and the rings and you have C1, C2, CN, C3, C4, C5. There is aslo a CM clearance which is in and around the same clearance as CN and often used to reduce noise. C1 has the smallest clearance and C5 the largest. The possible heat (disk transfer) and vibrations (road surfaces and out of balance) the wheels would really necessitate CN or C3 specification, C3 being the most common aftermarket type Since the bearing is a vital part in the bike, for your own safety stick with known brands
Re: rear wheel bearings - JZS 600 - 27-06-13 Check out the World Bearing Assocation for confirmation! Re: rear wheel bearings - justy1 - 27-06-13 cheers.... ive got 6204.EEC3 (J30)............. ope theyre the right ones? :\ justy1000 |
