painting the matt black bits :) - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: painting the matt black bits :) (/showthread.php?tid=64037) |
painting the matt black bits :) - Enceladus - 20-06-13 was getting fed up with the black plastic bits on my bike not matching the rest of the gloss black bike, so i broke out the aerosol cans and had a go. not a proffesional job, but looks better than the matt black ones. primer, 3 coats of black gloss, 4 coats of clear gloss top coat. thoughts ? [smg id=984 type=preview align=center caption="cover #1"] [smg id=985 type=preview align=center caption="cover #2"] [smg id=986 type=preview align=center caption="cover #3"] Re: painting the matt black bits :) - bozboz - 21-06-13 Not bad, you can get good results with jst a can. Sand now with a wet 2000grit. Then buff up with a paint cutter. That'll get rid of the orange peel in the 3rd picture
Re: painting the matt black bits :) - reillypadraig - 21-06-13 not bad, not sure if i would go as far as painting but back to black bumper spray makes it look shiney for a good couple of weeks for me, do rightly, but good job Re: painting the matt black bits :) - darrsi - 21-06-13 (21-06-13, 12:20 AM)reillypadraig link Wrote: not bad, not sure if i would go as far as painting but back to black bumper spray makes it look shiney for a good couple of weeks for me, do rightly, but good job That is similar stuff to the engine brightener spray that i used which caused havoc when trying to respray the engine, they're both silicone based which react with paint in a bad way! :groan Re: painting the matt black bits :) - Enceladus - 21-06-13 (21-06-13, 12:03 AM)bozboz link Wrote: Not bad, you can get good results with jst a can. Sand now with a wet 2000grit. Then buff up with a paint cutter. That'll get rid of the orange peel in the 3rd picturethat was initially my plan. paint, sand, repeat. life just got in the way as per usual! :rolleyes will sand them all down and do a proper job when more time allows. Re: painting the matt black bits :) - JZS 600 - 21-06-13 I like the silicone shine, dead easy to use and easy to top the shine up |
