Giving me the needle - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Giving me the needle (/showthread.php?tid=64013) |
Giving me the needle - darrsi - 19-06-13 I checked my TPS earlier, and the needle shot up to 10,000rpm so i switched off and went back in to work, and borrowed the torx tool ready to sort it out when i got home. Then as i left work i turned the ignition on and saw the needle stuck at 0rpm, so presumed that was part of the fault. That's when i noticed the bloody needle has somehow popped under the 0rpm stopper :'( [size=1em]Question is, do these clocks come apart for me to get to the needle easily enough?[/size] [size=1em]I haven't got time to look at it tonight but was wondering if anyone could point me (and the needle) in the right direction?[/size] Re: Giving me the needle - His Dudeness - 19-06-13 Everyone needs to back away from their tps's :lol You'll have to take the clocks off and take the cover off the clock and rotate it back around the other way by hand Re: Giving me the needle - darrsi - 19-06-13 (19-06-13, 06:51 PM)His Dudeness link Wrote: Everyone needs to back away from their tps's :lol Is that okay to do? I won't snap anything will i ? Re: Giving me the needle - His Dudeness - 19-06-13 No wont cause any problems. Happened on mine once and it just rotated back Re: Giving me the needle - darrsi - 19-06-13 (19-06-13, 07:09 PM)His Dudeness link Wrote: No wont cause any problems. Happened on mine once and it just rotated back So, d'ya think it's popped over/under the stop pin, or simply just dropped clockwise when i turned the ignition off because the 10,000rpm mark is over to the right side? The engine was ticking over when i took the photo', the needle goes to about the 5 o'clock mark when switched off. Re: Giving me the needle - His Dudeness - 19-06-13 It did a full revolution clockwise. Dont worry about it. It will be fine. Re: Giving me the needle - darrsi - 19-06-13 Cool, cheers Dude
Re: Giving me the needle - His Dudeness - 19-06-13 No problem
Re: Giving me the needle - darrsi - 20-06-13 Sorted......i reckon the needle just dropped the right side through sheer gravity when i turned the ignition off as it did it when i had it apart as well. Before switching off it was at the 10,000rpm TPS error code which is around the 2 o'clock position. |
