Near side fairing cracked round indicator - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Near side fairing cracked round indicator (/showthread.php?tid=63976) |
Near side fairing cracked round indicator - m4tth3w - 17-06-13 The fairing around my indicator on the near side of front fairing is crap and looks horrible is there any general well-known fixes for this issue. I think a round decal to stick around it would look good any suggestions. Thank you Re: Near side fairing cracked round indicator - Arfa - 17-06-13 Done same to mine, after a drop pushed indicator stalk in, cracking the fairing from indicator hold down to bottom edge. Yours must be worse, as the crack on mine is hardly noticeable. Either way, I was told a spot of glue and bit of plastic welding on the inside would sort it out. Just a case of finding someone local with these skills. Re: Near side fairing cracked round indicator - Lazarus - 17-06-13 where u based matthew? Re: Near side fairing cracked round indicator - bwizz - 17-06-13 Mine was broke of completely. I stuck it together with araldite, then i cut a piece of metal body repair mesh and fibre glassed it in from behind finally On the outside I ground around the break with a dremmel and filled it in with body filler I masked of the area from the rest and finished of with aerosol paint. can't tell it was broke now! Re: Near side fairing cracked round indicator - m4tth3w - 17-06-13 As u can see mine is on the shitier end of the shit scale ![]() ![]() I'm in barnsley Re: Near side fairing cracked round indicator - Lazarus - 17-06-13 ok - guy local in ayrshire can fix that - bit of a trek for you though !!! :| |
