Number plate mod - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Number plate mod (/showthread.php?tid=63940) |
Number plate mod - Loz - 15-06-13 I would like to get a slightly small number plate but it looks like it might look a bit naff on the original under tray unit, has anyone cut their undertray down and if so can it be done neatly and what did you use to do it ?
Re: Number plate mod - ghostbiker - 15-06-13 Trimed mine with a dermal but a hack saw would have been better as the dermal melted it rather than cut it. So then needed to go over it to clean it up. I didn't trim mine a huge amount but I have seen others hack it back a long way. 2 words or caution, 1 you need a reflector so do as I did and leave the old one in place on its tab or as others do and stick a stick on one on the plate itself. 2 even cut back a little and you get a LOT more spray up the back. I meen a LOT Will try to find a pic of it. Re: Number plate mod - ghostbiker - 15-06-13 ![]() ![]() Re: Number plate mod - Ian-man - 15-06-13 I cut mine back to just shorter than the number plate and stuck the reflector under the light where is says yamaha with double sided sticky tape. Re: Number plate mod - GrahamB - 15-06-13 Trimmed mine with combination of sharp knife & cutting disc on grinder. Had to heat the housing where my indicators now bolt to get them straight & remount the reflector but I think it was worth the effort. Marked it with masking tape before cutting to be sure I liked the lines. ![]() ![]()
Re: Number plate mod - seangee - 15-06-13 Re: Number plate mod - Loz - 16-06-13 Thanks for all the tips and pics, they have been really helpful, going to order the plate tonight and then get cutting :eek |
