Speed sensor - sprocket change - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Speed sensor - sprocket change (/showthread.php?tid=63919) |
Speed sensor - sprocket change - FazerBob144 - 13-06-13 Hi everyone, I guess you can call me a born again biker as I've just bought a 03 FZS600 after a very long time away! Thinking of changing the sprocket ratio to 17-46 from the std 15-48 to drop the revs for motorway cruising. As the 03 bike uses a front wheel speed sensor can this be a straight swap of the sprockets or do I need a gizmo to recalibrate the speedo? Re: Speed sensor - sprocket change - darrsi - 13-06-13 Sprockets have not got anything to do with the speedo, it's more to do with revolutions of the front wheel. Re: Speed sensor - sprocket change - Razgruff - 14-06-13 :agree the only thing that will effect the speedo is if you change the size of the front wheel for a smaller of larger one. changing sprockets just changes the gearing Re: Speed sensor - sprocket change - bwizz - 14-06-13 Hi I have an unused smaller rear sprocket if you are interested. think its a 46 Re: Speed sensor - sprocket change - Dead Eye - 14-06-13 I thought the standard sprockets were 15F 45R ? Re: Speed sensor - sprocket change - darrsi - 14-06-13 15f/48r Re: Speed sensor - sprocket change - Dead Eye - 14-06-13 Fair enough, thanks
Re: Speed sensor - sprocket change - FazerBob144 - 12-07-13 Thanks chaps, I asked the question as I believe earlier models ran the speedo off the gearbox output shaft, hence the need for a gizmo to recalibrate. Happy riding.
Re: Speed sensor - sprocket change - Punkstig - 12-07-13 (12-07-13, 12:34 PM)FazerBob144 link Wrote: Thanks chaps, I asked the question as I believe earlier models ran the speedo off the gearbox output shaft, hence the need for a gizmo to recalibrate. Not on the fzs600, its always been a unique digital speedo taken from the front whell, but yes there are quite a few bikes out there that use a sensor on the output shaft which would need an adjuster when changing gearing so can understand you're question! |
