Front wheel removal - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Front wheel removal (/showthread.php?tid=63880) |
Front wheel removal - tomlinscote - 11-06-13 Hi all, Any idea why there is no tool provided to remove the front wheel and what do you guys use, went to use the bike today and the back tyre was flat, got a bloody nail in it! Also any thoughts on only replacing the punctured tyre, I have pilot road ones on at the mo and obviously will have to get a new version looking at PR3 but can I just leave the front PR1 on as it has at least 2k of wear to go or should I bite the expensive bullet and replace the 2??? Tommo Re: Front wheel removal - fazer-rat - 11-06-13 leave the front one on no probs, the tool for the front wheel can be bought off ebay really cheap or you can use a m12 bolt with a pair of mole grips as the hole is 19mm i think if i remember correctly,, or it may be 17mm in which case you need an m10 bolt. just put the bolt in the grips and insert the head into the axle
Re: Front wheel removal - andydrz - 11-06-13 I use an old cortina wheel nut to help undo the spindle which is 19mm hex (or 3/4") like many other car wheel nuts. I have just put a pair of Pirelli Angel ST's on mine, £163 a pair from a link on here to a fellow on ebay
Re: Front wheel removal - ghostbiker - 12-06-13 brought a 19mm tool from local shop for £2 basicly just a chunk of hex bar i have seen some multi ones on ebay that do 4 sizes though. i think someone tried to use the plug socket spanner to remove the front wheel, it fitted but bent up easy so not advised
Re: Front wheel removal - AyJay - 12-06-13 I thought the spark plug tool was dual purpose for years until someone on here pointed out it wasn't for the spindle. Worked fine as long as the spindle isn't seized. the proper tool is peanuts though - just buy it and be done. It's like a spring puller for getting side and centre stand springs put on, you'll wonder why you never had one even if it's only used once in a blue moon. Or a proper oil filter wrench. Re: Front wheel removal - tomlinscote - 13-06-13 "as long as the spindle isn't seized" OR if the berk trying to undo the spindle forgets there is a clamp bolt and shears off the end of the torque wrench trying to undo the spindle first - DOH!! Tommo Re: Front wheel removal - AyJay - 14-06-13 Muffled giggle. Been there and done similar! Re: Front wheel removal - bwizz - 17-06-13 I got two car wheel nuts welded back to back, I keep it under the seat in case the rac man does not have a tool. I change my own tyres using, my jacked up astra with spare wheel rim fitted as bead breaking tool , I put an old car mat down to protect the wheel from ground abrasions, you need to be carefull with the front just tip it upwards at the rear to avoid presure on the brake discs, or alternatively a front wheel will fit in a large vice .I have cheep balancing tool bought on e bay for not much. If you have trouble making the beads seal when inflating the fitted tyre, just blow up a car wheel to about 60 psi remove the valve on the bike wheel and fit a foot pump hose of similar betwean the car and bike tyres, Ive fitted lots using this system , but if you are not confident in these things you must pay yer money etc, I would not change tyres before they are due, as they are expensive enough to change when they are knackered. |
