Front Hel Brake - 2 Line Kit Fitting - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Front Hel Brake - 2 Line Kit Fitting (/showthread.php?tid=63866) |
Front Hel Brake - 2 Line Kit Fitting - Andy Smith FZS - 10-06-13 Bought a set and put them on at the weekend along with another few things. I've got them set up and bled the brakes etc. I just don't think they sit properly, not sure if I'm making mountains out of mole hills or not :lol Let me know what you think? How are your lines routed? I forgot to take a picture looking down at the bars so ill get one up shortly. Re: Front Hel Brake - 2 Line Kit Fitting - Foxwood - 10-06-13 Pretty sure they should be routed around the rear of the forks and attached to the mountings on the forks. Re: Front Hel Brake - 2 Line Kit Fitting - keithfzs1000 - 10-06-13 :o :o definately as above, needs re routing :eek :eek :eek Re: Front Hel Brake - 2 Line Kit Fitting - Andy Smith FZS - 10-06-13 I did have them set up running down the back of the forks but the lines felt very stiff trying to get the banjos lined up with the caliper. Its not the standard set up on the fazer so I don't think I can use the brackets. Re: Front Hel Brake - 2 Line Kit Fitting - Dead Eye - 10-06-13 As others have mentioned, the lines should be behind the forks and they will fit in to the mountings for the existing hoses as this is how I have my HEL lines setup. They will be stiffer than stock lines but you should have plenty of room and space to get them routed ![]() Should be able to just whip the calipers off without having to remove the lines as well Re: Front Hel Brake - 2 Line Kit Fitting - Andy Smith FZS - 10-06-13 How are the lines set up at your master cylinder ? Ie closest one to the left furthest away to the right Do your lines both kink away for the m/c at the banjo? Re: Front Hel Brake - 2 Line Kit Fitting - Chris - 10-06-13 Hang on... Blue foxeye fazer, dark tint double bubble screen, clear indicator lenses, blue rad pipes... Is that my bike?? haha! Looking good Andy, as the others have said usually the brake lines are routed the other way around. Chris Re: Front Hel Brake - 2 Line Kit Fitting - Jc72 - 10-06-13 I just fitted the same to mine tonight, behind the forks and used the original clamps no problem. Bugger to bleed though, now got the lever tied back and re bleed tomorrow Re: Front Hel Brake - 2 Line Kit Fitting - Andy Smith FZS - 10-06-13 Chris - its getting there I know! still hunting for a belly pan but I've had plenty of things to do. As you can see from the pics I've posted on the threads tonight its abit tatty but that's next once its finally sorted and mot'd I can change the routing tomorrow when back from work. Just aswell I bought a big bottle of brake fluid. Re: Front Hel Brake - 2 Line Kit Fitting - Chris - 10-06-13 Looks good mate, as deadeye said you shouldn't need to disconnect the brake hoses, just take the caliper mounting bolts out and pass the caliper between the forks with the brake hoses still connected then put the calipers back on Chris Re: Front Hel Brake - 2 Line Kit Fitting - Dead Eye - 11-06-13 (10-06-13, 08:37 PM)Andy Smith FZS link Wrote: How are the lines set up at your master cylinder ? I honestly can't remember - I'll check it out for you in the morning, too cold outside at the moment and I'm a creature of warmth ^^ :lol |
