Front Sprocket???? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Front Sprocket???? (/showthread.php?tid=63826) |
Front Sprocket???? - Bigfellabuck - 08-06-13 Hi All, just checking the front sprocket on my bike and all seems to be well. There is a dotpunch mark on the gear shaft which tells me its been off to do the mod but how will I know??? How deep is the new nut compared to the old one? And the lock tab has been bent over in two positions telling me that thats extra security after a fix. Thanks guys Buck Re: Front Sprocket???? - unfazed - 08-06-13 If the nut has been replaced with the modified one it will be flush with the end of the shaft. With the original nut the shaft protruded over 5 mm out side the nut. The punch mark on the shaft is to align the gear linkage correctly and is always there. The slot in the linkage where the pinch bolt tightens should line up with the punch mark. Re: Front Sprocket???? - Bigfellabuck - 08-06-13 thanks bud appreciate your quick response many thanks buck Re: Front Sprocket???? - Punkstig - 08-06-13 Measure the width of the nut, 12mm I think is the new one! Re: Front Sprocket???? - Dead Eye - 08-06-13 12mm is the new size of the nut, 9mm for the old As others have mentioned, if its sat flush with the shaft then its the new one ![]() The dot mark is always present from the factory and the tab washer should always be bent over twice as I'm aware... Re: Front Sprocket???? - Bigfellabuck - 08-06-13 Hi guys, Thanks for your replies, mind at rest once again, Buck |
