Buying an FZS600 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Buying an FZS600 (/showthread.php?tid=63794) Pages:
Buying an FZS600 - Derpdiherp - 06-06-13 Hi all, found a low mileage 1999 fzs600 that I'm buying for after my test in a week. I've got a few questions about what to look for so far as common problems. I know that there is an issue with the front sprockets nut, I've informed the dealer about this and am hoping he keeps his word and checks it over, I'll check it myself when I get a chance anyway, if it is wrong, has anyone had any luck with Yamaha service centres in or around Manchester UK? Are there any more common problems with the bike that I should look out for before using it regularly? And other than the headlight mod (it's the eighties disco version before the foxeye) are there any other cheap mods that should be done to get the best out of it? Thanks guys Re: Buying an FZS600 - Dead Eye - 06-06-13 If it has the original steel exhaust on it then check it for rust or any signs of welding to show that its been repaired before. The stock pipes are the best for the bike, but they just don't last and are getting a little rare now. Most people swap them out for stainless steel ![]() Replacing the air filter with a K&N is a good way to go and replacing the rear brake caliper with the uprated thou caliper is a good mod but they are practically impossible to get hold of ![]() Other than that, standard checks all round for signs of scratches, scuffs etc to see if its been down on its side. Depending on what year it is, it may have preload adjusters on the top of the forks (98/99 don't have these, 2000 on do - if this doesn't match up then yours may have been replaced)
Re: Buying an FZS600 - Derpdiherp - 06-06-13 Aye it's 12k miles and the pipes look really really clean, this bike was someones baby - so I reckon it'll live on the stock ones for a long while yet (with liberal help from ACF-50). Ah I'll have a look at grabbing that air filter and keep my eyes on ebay if the rear brake caliper is a little shit, fingers crossed a breaker will put one up some time soon, but I guess it's not exactly a desperate job. And aye no preload adjusters as it's the 1999 version, really is the cleanest I've seen for the year: http://bikes.portfolio-europe.net/ezweblite/public/styles/std_website_3/view_thumb.asp?BRA_ID=4156&FRC_ID=0&PIC_ID=18007160&WIDTH=1280&HEIGHT=960 Deposits already down ![]() Re: Buying an FZS600 - darrsi - 06-06-13 The rear caliper will be absolutely fine as long as you give it a bit of TLC 2 or 3 times a year, as well as the front calipers too. It's only when they get totally neglected through different weathers that you will start getting issues. And i personally avoid using softer organic pads that create more dust as it's baked on dust that tends to cause problems with sticking pistons. I've been using the SBS ceramics on the rear of mine and they've been great. Re: Buying an FZS600 - Derpdiherp - 06-06-13 Noted on the pad selection, I'll give it a whirl when they're due for a change. And by TLC are we talking complete disassembly and clean? I've only had mine apart on the CBF once, wasn't too hard I suppose and I'm guessing brake calipers are brake calipers so it'll be similar. So far as upkeep - I'm an all year commuting biker, other than ACF50 all over it, anything else I should do to winterise it that's specific to the bike? Oh and what's thoughts on bellypans? Worth it with the downpipes being so prone to rust? Re: Buying an FZS600 - Derpdiherp - 06-06-13 Oh aye - one more question and I'm done I promise :b . With the headlight modification with both bulbs on - will that pass MOT? I'm really not sure. Re: Buying an FZS600 - darrsi - 06-06-13 If they're in good working condition then just push the pistons out a bit (not too much) and give them a good scrub with a toothbrush and brake cleaner, then reapply some red rubber grease on the exposed part of the pots. Keep doing that 2 or 3 times a year and they should behave themselves okay. Give the pads pins a good clean too, and put a thin smear of copper grease on them before putting them back in, just so the pads can slide sideways properly. If they can't slide and release properly then other problems will occur! Re: Buying an FZS600 - darrsi - 06-06-13 (06-06-13, 02:46 PM)Derpdiherp link Wrote: Oh aye - one more question and I'm done I promise :b .Mine does no with problems. Re: Buying an FZS600 - Derpdiherp - 06-06-13 Great thanks for all the help. Fingers crossed I'll be riding it next weekend
Re: Buying an FZS600 - Punkstig - 06-06-13 Nice looking bike there. As you're buying it from a dealer don't ask him, tell him to change the front sprocket nut to the thicker one before picking it up, they're only a couple of quid so no loss to him and piece of mind to you! Re: Buying an FZS600 - Foxwood - 06-06-13 Wow! That looks almost new! :eek I really have nothing to add to what's already been said. If you do change the air filter, might as well change the fuel filter while you're at it. Seeing as it has such a low mileage, it might have been sitting for long times, so contamination from the fuel tank and rubber fuel-lines might be possible. And the fuel filter isn't an expensive spare anyway. Re: Buying an FZS600 - Derpdiherp - 06-06-13 Aye punkstig I gave him a call about the nut today to catch up. It's getting done and he knows a Yamaha dealer, so it's all good. I'll check it myself anyway though - I prefer to have complete confidence in a bike. That's a good point Foxwood, I'll look into doing it as yeah it apparently has sat unused for some time during it's life. I'll check the last MOTs and services first though, hopefully it might not be needed. Re: Buying an FZS600 - red98 - 06-06-13 lots of advice there,looks like everything is covered,one thing to ask the dealer for is if its got any service history,bills reciepts etc......looks like a nice tidy honest bike....you cant beat a fazer
Re: Buying an FZS600 - darrsi - 06-06-13 Without meaning to sound like i'm putting a downer on things, 'cos i'm not, but a good valet can make a bike look like brand new if they're good enough at their job! mokin Re: Buying an FZS600 - dBfazer600 - 06-06-13 Hi Derp Bike looks fantasicly clean, keep an eye on the down pipes where it goes into one as this takes all the crap from the road (salt n stone chips) I use Scotoiler on chain and their SF 365 on down pipes and underbelly. Good luck with the test and keep an eye open for Fizzy Pie as he is on that side of the Pennines Daz Re: Buying an FZS600 - Punkstig - 06-06-13 One more common problem with the old fazer, all owners become a bit mental, or just more so if already a bit odd! Re: Buying an FZS600 - Derpdiherp - 06-06-13 (06-06-13, 04:29 PM)red98 link Wrote: lots of advice there,looks like everything is covered,one thing to ask the dealer for is if its got any service history,bills reciepts etc......looks like a nice tidy honest bike....you cant beat a fazer Yup, all service history is there - good on that one .(06-06-13, 05:21 PM)dBfazer600 link Wrote: Good luck with the test and keep an eye open for Fizzy Pie as he is on that side of the Pennines Cheers mate! Good to hear there's foccers my way as well, got a mate I go riding with but one more's always welcome if he's about, can't beat snake pass!(06-06-13, 07:00 PM)Punkstig link Wrote: One more common problem with the old fazer, all owners become a bit mental, or just more so if already a bit odd! Ha - so the front sprocket nut isn't the only nut job..
Re: Buying an FZS600 - Skippernick - 06-06-13 (06-06-13, 07:00 PM)Punkstig link Wrote: One more common problem with the old fazer, all owners become a bit mental, or just more so if already a bit odd! :lol Re: Buying an FZS600 - Dcock - 06-06-13 If you don't mind me asking, how much are you paying? Re: Buying an FZS600 - Derpdiherp - 06-06-13 About £1900 or something close to that. A little pricey for the year but it seems looked after. |
