Clutch knock - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Clutch knock (/showthread.php?tid=63791) |
Clutch knock - Superfour Tom - 06-06-13 Hi guys, Just wondering if the knocking from my clutch is normal. When riding around and come to a halt, I take it out of gear and release the clutch and it gives a knocking noise until i pull the clutch back in. When first firing up (stationary), i find the noise will only come when i clutch-in, select 1st, Back to neutral then release the clutch again. :\ I have just swapped the engine, the new one is a 14k minter that has no rattles or knocks (apart from this), The old engine did it too, but i cant make my mind up if this new engine is worse? Can't think of anything other than the release bearing in my head. Or are these bikes just like this? Cheers, Tom Re: Clutch knock - Andy FZS - 06-06-13 Out of balance carburettors can cause the clutch to rattle have these been checked recently. Andy Re: Clutch knock - ade the blade - 06-06-13 my vote is with Tom sounds very much like release bearing ( most manual cars have the same noise to a certain degree ). wouldn`t lose sleep over it..........just ride it as normal and sort it if it gets really bad. does the clutch operate ok otherwise mate? cheers Ade
Re: Clutch knock - Superfour Tom - 06-06-13 (06-06-13, 06:26 AM)Andy FZS link Wrote: Out of balance carburettors can cause the clutch to rattle have these been checked recently. They were balanced about 2 weeks before swapping the engine, I didn't bother when i swapped the engine. But i'll re-balance and let you know. (06-06-13, 09:33 AM)ade the blade link Wrote: my vote is with Tom Yeah, the clutch is fine.. Just this annoying knocking. Re: Clutch knock - otis - 08-06-13 I had the same thing on mine last year, changed the clutch, balanced the carbs but was still there. A few weeks later the bottom end let go :'( problem found. New engine is quiet
