easiest way to adjust rear suspension ? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: easiest way to adjust rear suspension ? (/showthread.php?tid=63703) |
easiest way to adjust rear suspension ? - Enceladus - 31-05-13 been trying for 15 mins or so to move the rear suspension on my fzs600 but i can't get it to budge. been hanging off the "spanner" like a monkey and it won't move. is there an easy way please ? at the moment it is on the 3rd groove from the tallest end and i want to move it down a notch or two. thanks ![]() Re: easiest way to adjust rear suspension ? - His Dudeness - 31-05-13 how crusty is the shock? do you have the right tool? you could try a liberal dose of wd40 and a pipe over the spanner to give a bit more leverage Re: easiest way to adjust rear suspension ? - Enceladus - 31-05-13 shock and "collar" (don't know the right term) look v clean and shiny. using the tool in the tool kit have given it a squirt of grease, but still no joy. best on centre stand or side stand ? thanks ![]() Re: easiest way to adjust rear suspension ? - Skippernick - 31-05-13 Have you put the extension bar on the c spanner that comes in the tool kit, it is quite stiff! :lol Re: easiest way to adjust rear suspension ? - Enceladus - 31-05-13 (31-05-13, 08:45 PM)Skippernick link Wrote: Have you put the extension bar on the c spanner that comes in the tool kit, it is quite stiff! :lolhadn't thought of that ! :rolleyes will give it a go
Re: easiest way to adjust rear suspension ? - darrsi - 31-05-13 You need a bigger monkey :lol Re: easiest way to adjust rear suspension ? - Enceladus - 31-05-13 (31-05-13, 09:52 PM)darrsi link Wrote: You need a bigger monkey :lollol ! :lol Re: easiest way to adjust rear suspension ? - Fuzzy - 01-06-13 (31-05-13, 08:09 PM)Enceladus link Wrote: shock and "collar" (don't know the right term) look v clean and shiny. Best on centrestand and it's a hell of a lot easier with the handle attached to the spanner! |
