Dent puller - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Dent puller (/showthread.php?tid=63697) |
Dent puller - simonm - 31-05-13 As I have widely advertised in my shy way I have a substantial handlebar shaped ding in my fuel tank. It has definite creases and I don't think a suction puller would cut the mustard. To compound the issue the cost of the tank vs a body shop makes it financially hard to justify the cost. So two questions: - is the fazer tank twin skinned? - should I just leave it dented or should I have a go with one of these? http://www.ebay.co.uk/itm/SPRING-SALE-POWER-TEC-92376-PAINTLESS-DENT-REMOVAL-SLIDE-HAMMER-9-GLUE-PADS-/181145195228 I know worst case scenario is a wrecked tank and I should empty it of fuel first but any other advice ? Re: Dent puller - BBROWN1664 - 31-05-13 Unless its causing a problem, I would leave the dent alone until funds allowed for a new tank or a professional repair job. Re: Dent puller - red98 - 31-05-13 pretty sure the tank is single skined......i`ll be surprised if that slide hammer will pull the dents out ,i dont think it will be man enough....the ones i have used in the past have a self tapper on the end but does mean drilling a hole in the tank and welding up when finished but will pull the dent out........there are other more expensive types which fuse a rivit to the surface and then use the slide hammer attached to that and simply cut off when finished.....expensive and probs not worth it for the one job
Re: Dent puller - dickturpin - 31-05-13 have you thought of one of the 'just dents' type repairs for cars? I had a car door dented in a car park and that sorted it....99% better. £30cash! Re: Dent puller - Dead Eye - 31-05-13 When I needed a new tank I picked one up second hand for £45 delivered so not exactly expensive. The breaker yard I went to wanted £90 at the time... I'd just leave it be for now and get a second hand one. Don't worry about colour too much, can always spray it, have it vinyl wrapped or cover it with a tank bag Re: Dent puller - Fazerider - 31-05-13 If the damage is all below the original surface level then car body filler and some touch-up paint should make it almost unnoticeable. Re: Dent puller - alan sherman - 31-05-13 I had a football sized dent in the top of my tank. A suction cup on a phone holder for the car windscreen pulled it out! The tank must be single skinned. Infact you can see on the weld line the two pieces of material. Re: Dent puller - chris.biker - 31-05-13 A photo of the dent in the tank would be interesting to see. Re: Dent puller - Dead Eye - 01-06-13 There's a few images of the damage in the 600 forum; found this thread by our dear simonm highlighting the unfortunate "dent" http://foc-u.co.uk/index.php/topic,7196.msg68664.html#msg68664 Re: Dent puller - red98 - 01-06-13 reading back through this thread , it looks like DICKTURPINS idea is the best.......think i`ve seen one near me called DENT BUSTERS, as you have a crease they wont be able to remove it completely but a skim of filler will sort that out
Re: Dent puller - chaparral02 - 01-06-13 Maybe you be better off making an offer on something like this one http://www.ebay.co.uk/itm/yamaha-fazer-600-fuel-tank-from-a-1999-model-/200922799185?pt=UK_Motorcycle_Parts_13&hash=item2ec7ee9c51 (PS: don't know if it from the same model year as your bike) Re: Dent puller - simonm - 01-06-13 (01-06-13, 12:40 AM)Dead Eye link Wrote: There's a few images of the damage in the 600 forum; found this thread by our dear simonm highlighting the unfortunate "dent" http://foc-u.co.uk/index.php/topic,7196.msg68664.html#msg68664 Thanks for pointing out a pic of it. Appreciated.
