fuel pump - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: fuel pump (/showthread.php?tid=63671) |
fuel pump - phil on a fazer - 29-05-13 pleae help :o went out 2 start my fazer today after about a 3 week lay up (battery has been charged though). Turned ingnition and the fuel pump clicked away as normal, hit starter, turned over but didnt catch - this is normal, my fazer doesnt like being started if it has been riden for a week. BUT..when i let go of the starter, the fuel pump clicked away a bit more??? ignition off......back on, fuel pump clicks for 5 secs but kind of sounds like theres a loose connection (the sound isnt "even" if that makes sense) so i did igntion on...fuel pump clicked for 5 secs...ignition off....back on...clicks for 5 secs....AND SO ON, it just keep clicking away always for 5 secs. This isnt right is it??? never done it before and i thought the fuel pump just primed the carbs? so why is it doing it for 5 seconds every time the igntion is switched on?? Re: fuel pump - Falcon 269 - 29-05-13 The fuel pump shuts off when the float bowl level is correct. Perhaps the pump is not getting the pressure resistance expected and so continues to operate for a while longer. Could be symptomatic of an issue with the float needle seat O-rings, Phil. However, start by checking the obvious things like electrical connectors, fuel lines and fuel filter before you assume it's inside the carbs. Re: fuel pump - phil on a fazer - 29-05-13 (29-05-13, 05:32 PM)Falcon 269 link Wrote: The fuel pump shuts off when the float bowl level is correct. Perhaps the pump is not getting the pressure resistance expected and so continues to operate for a while longer. Could be symptomatic of an issue with the float needle seat O-rings, Phil. ok. i do actually have a brand new fuel filter in my garage. So i will fit that, dont you have to remove the fuel pump to do so?? (if so, that will give me chance to spray up / clean the connectors) thanks |
