clutch spring question - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: clutch spring question (/showthread.php?tid=63604) |
clutch spring question - solorider - 24-05-13 I have sourced a complete genuine Yamaha clutch plate set,as to the springs is it worth going for an uprated spring set or is it best to stick to standard? Re: clutch spring question - solorider - 25-05-13 anyone??????????? Re: clutch spring question - snapper - 25-05-13 my opinoin is if it aint broke dont fix it ! have you had clutch slip with the standard springs ? up rated will make the lever stiffer more strain on your hand and the cable, maybe more likely to break it . but thats only my opinoin ! and not worth much ! Re: clutch spring question - solorider - 25-05-13 I have had no slipping but my clutch is worn out,the bike has 71k miles on it and when I get it apart I thought a set of new springs wouldn't go amiss Re: clutch spring question - snapper - 25-05-13 new yes, but uprated is another thing |
