XJR 1300 Springs in Gen1 forks for a firmer ride - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: XJR 1300 Springs in Gen1 forks for a firmer ride (/showthread.php?tid=63584) |
XJR 1300 Springs in Gen1 forks for a firmer ride - kebab19 - 23-05-13 Touched on this briefly in another thread, but for anyone fond of pies, here's a fairly cheap mod to sort the front-end out a bit more. The forks springs from the XJR1300 can be fitted inside the Fazer's forks, and as they support a bike over 20kg heavier they are better suited to heavier riders if transferred. I found a set that were Ohlins aftermarket springs, claiming to be a further 10-15% stronger than the standard XJR springs, so more suitable for heavier riders. Instructions: no point in me re-inventing the wheel, so just follow 'Bigworm's instructions for opening up the front forks: http://www.yamahafz1oa.com/bigworm1sforkupgrade.shtml Reassembly of forks is obviously reverse order of these instructions once you've switched springs & spacers over. You need to make two smaller spacers in order to fit the longer XJR springs, I used a metal tube from B&Q. Take your original spacer down there & find a metre of metal tubing that has the same dimensions. I *think* it was 10mm diameter tubing with 1mm wall thickness. My Ohlins springs were 388mm long so the spacers were 24mm shown below. Note that other XJR springs may be a different length so you may need longer / shorter spacers to match! Difference in spring / spacer length between XJR & Fazer ![]() ![]() New setup inside fork leg, note the spacer is far shorter than the original Fazer's spacer I found the springs to be a good improvement over standard setup, after backing the preload adjusters right off to minimum. I also use much lighter 2.5w fork oil, which I feel also helps compliance over small square bumps. Obviously other springs from 43mm forks may well be suitable (and not just from Yamaha's), so it's a case of cutting the spacers to size to equal the length of the original fazer spring / spacer setup. |
