Backfiring on overrun - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Backfiring on overrun (/showthread.php?tid=63553) |
Backfiring on overrun - Speed of Dark - 21-05-13 FZS 1000 Just wandered if you knew what the problem might be. Have not touched any settings. It does everything else really well Thanks Speed Re: Backfiring on overrun - Ian-man - 21-05-13 Popping on overrun can mean a small leak on the exhaust system. From my HTC using Tapatalk Re: Backfiring on overrun - wessiedave - 23-05-13 You say you haven't touched the settings but is it a standard can ? Re: Backfiring on overrun - Tiberius Onklevaart - 23-05-13 Firing on the overrun means YOU'RE AWESOME. Keep it up Re: Backfiring on overrun - Speed of Dark - 24-05-13 (23-05-13, 10:22 PM)wessiedave link Wrote: You say you haven't touched the settings but is it a standard can ?Yes the can is standard The bike is as completely standard Re: Backfiring on overrun - wessiedave - 24-05-13 Try removing the can and cleaning the joint area, copaslip or grease the connection a little bit and see if that cures it Re: Backfiring on overrun - Camshaft - 24-05-13 Mine's allways popping anything over 3.5rpm and I love it...........!!!! Re: Backfiring on overrun - Speed of Dark - 24-05-13 (24-05-13, 07:41 AM)wessiedave link Wrote: Try removing the can and cleaning the joint area, copaslip or grease the connection a little bit and see if that cures itThanks I will give it a go I can say it has never popped until last year It will overrun ok for a bit but seems to build up to a bit of a bang then it's ok for a bit longer bang again can it be un burnt fuel firing off in the can? Re: Backfiring on overrun - VNA - 24-05-13 Is it backfiring or just popping. Big difference. Re: Backfiring on overrun - Speed of Dark - 24-05-13 (24-05-13, 06:17 PM)VNA link Wrote: Is it backfiring or just popping. Big difference.Definitely backfiring not popping Speed |
