Leak.... but what is it? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Leak.... but what is it? (/showthread.php?tid=63410) |
Leak.... but what is it? - babemagnet - 13-05-13 My gen 1 fazer 1000 has started oozing brown gunk from small hole in left hand engine casing. Have owned various fazer 1ooos over last 10 years and this has never happened before. Any ideas?.....will try to attach photo Re: Leak.... but what is it? - Fazerider - 13-05-13 Looks like engine oil coming from the spark plug well drainage hole so a damaged cam cover gasket would likely be the cause. Re: Leak.... but what is it? - snapper - 13-05-13 might be a loose plug ? # if your lucky :'( Re: Leak.... but what is it? - ghostbiker - 13-05-13 Deff looks like oil in the picture, with out better info and pic etc I would say a seal or gasket is leaking in to the plug reses. Re: Leak.... but what is it? - Tmation - 13-05-13 When you have fixed the leak change the oil it looks dirty :lol Re: Leak.... but what is it? - slimwilly - 13-05-13 Looks like it only leaked when stood still,,,,why??? Re: Leak.... but what is it? - ghostbiker - 13-05-13 Parked on side stand? Leaning on that side let the pooled oil seep out maybe Re: Leak.... but what is it? - chaparral02 - 13-05-13 Would it be possible that water from washing or rain has got into the area where the spark plug goes that the sparkplug cap normally seals and it just a some dirty rusty oily water coming out of the drain hole.. Re: Leak.... but what is it? - babemagnet - 13-05-13 Bike has been sitting in shed since last july. has not got wet. Oil has just been changed and is a nice red colour still. After what has been said above I am also perplexed as to why it only seems to drain out when on side stand and not when in motion. I am now worried as am due to tour Spain at end of june and am now questioning whether it will do about 5000 miles. Should I fix before I go or will it last the holiday? Re: Leak.... but what is it? - Tmation - 13-05-13 (13-05-13, 11:32 AM)Fazerider link Wrote: Looks like engine oil coming from the spark plug well drainage hole so a damaged cam cover gasket would likely be the cause. Seriously, I think the above is bang on the money. Lift the tank, pull the plug leads and have a good look with a torch or as snapper says it might be a loose plug because that is not clean oil coming out of that hole. Unless you are seriously unlucky I think you will find it is a quick fix. Good luck Re: Leak.... but what is it? - Fazerider - 13-05-13 You should at least investigate it before going on a 5000 mile trip! If it is just a bit of seepage past the cam cover gasket you'll probably have no problem beyond a slightly messy looking engine and the need to top up the oil occasionally, but it's not impossible that the cause is something critical. There's no point in having a ruined holiday for want of getting your spanners out or taking it to a mechanic if you're not confident of tackling the job yourself. Re: Leak.... but what is it? - eddie - 13-05-13 Or it could be rusty water from the metal coolant pipe that goes into the top of the head I have noticed mine has surface corrosion.. I would check the the hose connection onto it Re: Leak.... but what is it? - slimwilly - 14-05-13 Get it clean and give it some gas, go for a good ride and see what happens, hope you come back safe Re: Leak.... but what is it? - babemagnet - 16-05-13 Thanks foe all thwe above............turns out it was just shitty water sitting in top of engine because drain hole was blocked. As bike was on main stand and not being used this water just got shitty as it wasn't being boiled off with use. When put on side stand for first time after sitting it slowly oozed out. Took it to garage who blew all the crap out with an airline. Checked the plug recesses and no oil leaks...........Big Phew..... No leaks and no cost......Spain here I come.......one again thanks for all suggestions. Re: Leak.... but what is it? - tomlinscote - 16-05-13 Result ![]() Tommo |
