error code help - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: error code help (/showthread.php?tid=63343) |
error code help - robcaton1234 - 09-05-13 hey there just went to start my bike and its showing error code 12 with the engine management light on and bike won't turn over??!!!! Any ideas anyone????? :'( :'( :'( Re: error code help - DekF - 09-05-13 Hi It's the crankshaft position sensor. The 2 core wire runs from the rightside engine cover to under the tank. It is black plastic coated & is clearly visible. Check to make sure it hasn't been damaged or unplugged ( highly unlikely). If not you'll need a new one. Have you worked on it lately. Edit: The wires are black & grey & if they are not damaged/disconnected test with an ohmeter across them & the reading should be 336 - 504 ohms. |
